Loose steering feel, lower steering shaft?
chartersj
I just took this video today of my steering rack moving at full lock. Is this what you guys are talking about?
Would this cause steering wander and bump steer?
992dr
Eastern N.C.
I'm bringing this back from the dead. Though its really not that old.
Like Julian's video above shows movement, mine is doing the same but a bit worse. I can feel it while driving as well as see it in the wheel movement. Lots of play.
This is my biggest issue, tire wear and finding the culprit.
Can I be safe to say that this movement in my steering is causing an issue with my alignment?
I'm getting serious wear on the inside of each front tire.
Just to be sure, this kit will below will resolve any steering issues?
https://www.ebay.com/itm/Arm-Bushin...ash=item3d3da3deb0:g:olQAAOSwB-1Y3pmh&vxp=mtr
What method did you guys use to replace the bushings?
Thanks
992dr
Eastern N.C.
So, anyone have any luck on replacing there bushings?
I've been googling the heck out of this topic and I cant find anything. Its always for another vehicle.
Just looking for the process in which to remove and install, preferably a video haha.
992dr
Eastern N.C.
Well, since no one has done this I'm going to bite the bullet and order these.
I just wanted to make sure there wasn't any other aftermarket options available before I order them.
EDIT: Another question. Is there an aftermarket rack available instead of a reman? I've been reading that the rack bushings are not serviceable and am curious as to who has gone through this successfully. I may be leaning towards a new rack.
Any info would be much appreciated
Thanks
992dr
Eastern N.C.
Hmmm, no replies at all.
Looks like I'm going to lean towards replacing my rack. Yay
Warriorpluto
Lol why are you talking to yourself man I'm just messing with you. Keep us updated. I have the shaking in the steering wheel when the truck is idling. I want to get rid of the sounds asap
992dr
Eastern N.C.
I was secretly talking to you haha.
Shaking when its idling? Hmm, not sure its the same thing as this issue.
I will for sure. I'll post everything in this thread, no need to start a new one.
sub'd i'm curious how this plays out
I'm just as curious you haha.
I'm hoping to get the bushing Saturday, if everything pans out they'll go in Sunday. Otherwise, it'll have to wait until next weekend. Weather permitting of course haha.
992dr
Eastern N.C.
Surprisingly they arrived today haha. This was after they told me I'd receive them Monday.
Well, if anyone is interested, this is what you get and the company that makes them. They are available through that eBay link or they are also available through Amazon. Same price which ever way you go.
I'm trying to figure out the whole pressing situation.
I'd like to get this done asap but I will not rush this and end up screwing it up in the process.
So, bare with me and I'll be back as I progress.
Warriorpluto
Yes sometimes i can hear the steering shaft vibrate from the steering wheel.
992dr
Eastern N.C.
Ok well, it did not happen today.
I'm not prepared at all and cant afford to be without my ride for the weekdays.
I don't think my plan on renting a bushing/bearing press is going to work in my favor from past experiences.
So, I need to get some fluid for my shop press, find some plugs for the steering lines and rack and find something to press the old bushings out. I think I have something to press them in. I'll source something from work or turn something down on the lathe.
I will be starting Friday as soon as I get home from work. That way I can get it up on jack stands and get the wheels off. I wasn't expecting to have remove the whole rack but that's what it looks like I'll be doing.
For anyone doing this, you need to make sure your steering wheel is strapped so it will not move or the clocking spring could break.
There's a video by 1AAuto on YouTube that's pretty detailed on how to replace a steering rack.
Sorry to babble and for not having any progressive info but I will have more Fri/Sat
Have a great night :)
BG1988
if your replacing the steering rack go with the electric power steering rack.. you will have to pluck it out of a hybrid though..
aka EPS.. There is no bump steer at all.. really nice I can let go of the steering and you can really see how not so straight roads really are..
it requires user input, without user input the ESP motor is off .. unlike hydraulic PS.. no bump steer.. whining or having to deal with Power steering fluid.. saves upto 10HP
992dr
Eastern N.C.
Unfortunately I'm just replacing the bushings in my rack. Cant justify spending so much for a rebuilt unit when I can do it myself.
Though that sounds interesting about the electric rack. I'm going to look into.
Thanks for sharing Brent, its much appreciated
992dr
Eastern N.C.
Oh hey while I'm here, I did find something to use to press out the old as well something to press in the new.
So, I'm on schedule to start Friday as long as the weather permits.
992dr
Eastern N.C.
Got it jacked up and wheels off for now.
This is nice.
I'll be calling the shop who did my alignment to discuss some kind of deal. This should have never gotten to this point to begin with. If they do not budge, I'll have to find somewhere else to go.
992dr
Eastern N.C.
This was as simple as it gets and it didn't take much time at all and it definitely helped to prepare ahead of time.
Surprisingly, the bushings came out smoothly and went in just as smooth.
One thing to note is, the bushings are aligned in a certain way. There is an alignment washer that spans both bushings that fits between the rack and crossmember. It is pressed on when torqueing down the bolts.
You must have this aligned properly or the bolts will put a great amount of pressure on the bushing causing premature wear.
Otherwise, this was easy. I didn't throw anything, break anything or even curse during the entire install. That tells you a lot if you know me haha.
If anyone has any questions, feel free to ask. I'm not the greatest and the details but if there is something in particular you'd like to know, fire away.
EDIT: the only thing I didn't do was replace the round bushing that goes around the passenger side of the rack. You need some kind of crimp and tool and since it was pretty firm, I let it be.
992dr
Eastern N.C.
Little update, not much.
After driving round for a about a day, I am pleased to say this as help tremendously.
AND, when I back into my driveway I always heard noises (thinking it was my rear suspension) when in all actuality it was my steering rack.
Now, I have to deal with the shop who did my alignment twice and hope they give me a deal AND let me back there to watch. If not, I'll be going somewhere else.
petethepug
Michael
SoCal
Purch our 08 Denali AWD in 14 and 96k. Steering feel was ok. Up until last Mo 3-2019, more alignments were needed and steering input was increased to every 2-5 seconds. Noticed the rack boots were leaking and lock to lock was clucking at full lock.
Got our service contract to replace the rack at 136k. I had to pay $2h to upgrade to a genuine AC Delco rebuilt rack because the SC Co wanted to install a generic junk rebuilt rack. Paid for outer tie rods as the inner were incl w/ new rack.
The SC Co waived our $100 deductible since we didn’t slam them at the GMC dealer this time. The tech took another $100 off since we had a 5 yr alignment policy somewhere else. Essentially 100% of the part/labor we’re covered.
The outcome of a new rack, inner and outer tie rods was clear. Less play, almost no corrections needed in straight line driving and smooth as buttah. The control arm bushings are next on the maint list. Wheels are stock 20’s. There’s a slight hmm from the new rack. Waiting to see if it’s air, p/s pump or the rack. Either way you’ve gotta get into the ALL the serviceable bushings on the rack components after 100-125k miles.
BadDaddy2003
