PG01
Up here to the right
Okay, the pace is right, you will complete the 12k in your way back from Key West next month.
Right?
Sent from my Pixel 2 XL using Tapatalk
Somewhere around that, maybe 8500-10k. Im going to change the oil this weekend and take a look at all fluids and a general look at everything else.
Did you say you have a cai and exhaust?
Tylus
South GA
Thanks to a member’s writeup (DWSmoot), saved $80 over the GM Accessories part and got the dynomax 304 stainless polished tip for $22. Perfect fit. March 1st, it’s 15 degrees out. Don’t care though, I’m thinking spring
care to help me out with that? I can't find anything that cheap
humer101
NJ,USA
What is cai?
Stanky
Got a Magnaflow 11229 & stainless steel tip installed. They deleted the butterfly valve as well. I went ahead and bought the Range AFM Disabler to go with it. Sounds much better with the range installed, no drone. Here is a start up clip. The reason I say semi-cold start was because it sat for about 8 hours while I was at work before being started up again, rather than being in the morning. Let me know what y’all think.
thepiombino
Thanks! Funny story -- got through the highs and lows portion of the show. Got a call from a buddy of mine asking if I wanted to drop a K&N CAI while I had the OEM box out. Long story short, fogs put on the back burner, but I now have a new CAI and the car sounds and looks AMAZING!
Sent from my Pixel 3 XL using Tapatalk
Finally got the fogs in. Pretty good match with the HIDs.
Off Road Pedia
