CJ Rodarme
Is it possible to do away with the OEM roof rack on my yukon? Can I just unbolt it and call it good or is there holes to fill?
there will be holes to fill. It's the hole the bolt screws in to. Some people get short bolts to put in it's place. there's a few different products that can do it.
I took my rack off and just put the stock bolts back in the holes. I did that just to keep debris out of them. With the stock bolts, just the heads are visible--not a biggie imo. You could always get bolts with flat heads instead of the stock rounded heads.Is it possible to do away with the OEM roof rack on my yukon? Can I just unbolt it and call it good or is there holes to fill?
My opinion, the GMT800's look much better than the 900's with the rack delete. 900's tend to look naked without a rack.I took my rack off and just put the stock bolts back in the holes. I did that just to keep debris out of them. With the stock bolts, just the heads are visible--not a biggie imo. You could always get bolts with flat heads instead of the stock rounded heads.View attachment 215038 View attachment 215039 View attachment 215040
That thing looks amazing! Is there anyway to see what the bolts look like exposed? I wanna do this to my z71, Also deflared it looks so much cleaner, and they look even cleaner debadged. I might have to do those things, Love your truck though so clean.Took mine off . Just filled the holes with oem bolts and that was it. Much cleaner look View attachment 216132View attachment 216133
I just removed the roof rack on my 2000 Yukon and put the same bolts back in with a little sealer on them. I would like to replace them with shorter stainless ones, Anyone know the size threads?
Thanks,M6x1.0 worked for mine perfect.
