Replacement
Jacob Metz
Weslaco, Tx
has anybody ever actually swapped out this piece for the center console. If so what did you put in it’s place.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
I scored this at the local pull-a-part, if your lucky you can find this too.
Very hard part to find. Was gonna order it through work but it was discontinued.
Either this option, make your on pocket somehow, or upgrading to the 03 center console.
S33k3r
Dallas, Texas
I have no need for it. And was wondering what all could fit in there
With what you can replace it, I am unsure -- I am sorry I don't have an answer. But I was looking at what the console piece gave you and thinking someone with a family might want that piece to mod their ride.
Jacob Metz
Jacob Metz
Weslaco, Tx
It’s there. I have no use for it. It’s a little cracked. But I don’t need it since I upgraded my radio
NoReverseYukon
NE Wisconsin
I saw several of these today at my local salvage yard. I also have no need for rear controls. You can find these in Suburbans or Tahoes ; same size.
Be careful when removing, not only must you remove the cupholder fold-down to get at 2 phillips, but there are also 2 metal clips you need to depress to remove the tabs at the very bottom of this panel. You get to them thru the interior "box" you have to remove. You can't get a straight shot at them; you will be tempted to twist them - do not do that ! The plastic to which these metal clips are attached breaks easily.
Drewphil
