What gives?!
riverracerxxx
SoCal
my drls wont come on. Thought the bulb was burned out. It wasn’t checked the fuse/fuses, they look good. Checked the setting on the dash computer. It’s set to ON ‍♂️♂️♂️
if everything checks out and like Nate said make sure the parking brake isn't set, then try cleaning the drl's bulb connector since these are on all the time the connectors get hot and warp and can get so they don't make contact very well anymore, I used to have to clean mine on my nbs every once in a while and bend them in so they made good contact again. Also if you are not aware they do not come on until you are in drive.
riverracerxxx
riverracerxxx
SoCal
Thanks. I’ll check that out.
Eickybobby5050
