Pushbutton transfer case swap
EfiniMotorsport
I have an 04 Yukon Denali with full time AWD. I'd like to swap the transfer case for something that will give me 2hi, 4hi and 4lo with the push button. I know the regular Yukons and Tahoes use them but not sure if one is any stronger than the other and what years will fit with the least amount of work. I know I'll need the TC itself and the switches but what else is needed to control it? I haven't been able to find much on the swap.
mikeyss
Longmont, Colorado.
The front axle is also different as in it doesn't have a center axle disconnect. So even if you switch the TCase out, the front axle will still be locked in. Also the AWD system in those years did not have the G80 option because of how traction control is programmed to work. If you change to the Tahoe selectable TCase, you'd be left with a locked front axle, and an open rear end.
E
EfiniMotorsport
I thought the rears on these has an lsd. I'm ok swapping the front diff if needed.
E
EfiniMotorsport
No G80. Is there a list somewhere that I can use to decode all the options?
RPOcodes.com. DUH
RPOcodes.com. DUH
For possibly better accuracy, meaning the description of the code for your model and year, try contacting GM directly by chat or email. Alternatively, you can pay $5 at Compnine and decode up to 5 vehicles, handy when you're looking to buy.
dnbri512
