Rear Main Seal job, Pan, etc - 07 Yukon Denali 6.2
donjetman
I'm a DIYer and have my own lift at home.
Day 1
I'm starting the process of changing the rear main seal. While I'm at it I'm gonna:
1) Replace the trans fluid and filter, 2) Install oil pan gasket 3) Replace a leaky trans cooler line, mine has an external cooler, 4) new starter, 5) new alternator, 6) install new oil cooler adapter block off, 7) Installed new improved valve cover # 12570427. I recently installed a catch can. It is collecting an once of oil every 100 miles, NOT GOOD.
It took me half a day to get the 6 nuts off that hold the exhaust pipes to the exhaust manifolds. Lots of PB Blaster, patience, and elbow grease. I borrowed a special socket to get the O2 sensors out.
Here's a link to pictures I've taken on Day 1 of this massive undertaking.
https://imgur.com/a/Qo0LX1T
View media item 27363View media item 27372View media item 27373View media item 27378View media item 27376View media item 27377View media item 27379View media item 27380View media item 27381View media item 27375View media item 27374
thompsoj22
how will you support the trans, will you bring it back just far enough to do rear main and than go right back in? thanks for showing this procedure as eventually ill need a trans and the rear main just makes sense at that point. i cant imagine laying on my back in the garage, that lift is the way to go!!!!!!
donjetman
donjetman
The lift is nice. Its rated for 10K Lbs. Cost was about $3500.
Are you going to have it tuned?
What are the pluses and minuses? I don't want to make its gas mileage any worse than it already is. And I don't need another hotrod. The main thing I'm gonna use this vehicle for is driving back and forth, 1000 miles each way, between our TX and CO homes several times/yr.
I am working by myself and I'm letting gravity help me. I will lower the vehicle close to the floor. I will support the engine/trans with a jack while I remove the transfer case with a separate jack. Then I'll use a transmission jack to remove the tranny.When I put it back together I'll probably need a helping hand.
A BlackBear tune basically makes the vehicle more driveable and for me, the biggest benefit was in the improved performance of the transmission. It shifts faster and sooner now. The engine makes more power and is ever slightly more fuel efficient too.
As for performance gains when comparing it to an exhaust system or headers, the tune is the best bang for your buck.
donjetman
donjetman
AWD Transfer Case Removed Today
Once the tranny cross member is out, the tail shaft of the transfer case can be lowered until it rest on the non-removable mid cross member. At the same time the engine oil pan comes close to touching the cross member under it. This tail shaft low attitude makes it easier to get the top nut loose(15mm crows foot) of the six nuts that hold the transfer case to the tranny, take the vent lines loose, and it will make it easier to remove the upper bolts/nuts that hold the tranny to the engine. To get the TC off the tranny, take the weight off the tail shaft with jacks under both the tranny and TC. The pictures show what type jacks I use. Smack the tail shaft with a dead blow hammer the TC will come loose from the tranny.
The tranny was working fine, so I'm NOT going to rebuild it now.
View media item 27396View media item 27397View media item 27398View media item 27399View media item 27400View media item 27401View media item 27402View media item 27403View media item 27404
buddyhotrod
That’s a nice set up.
Congrats
If you’re going to do the rear seal might as well knock it all out while you’re that deep into it.
Front seal, rear seal, oil pan gasket, timing chain, timing cover gasket, new oil pump.
I did the new gaskets for one of my Tahoe’s and for my nieces suburban.
Each time I also replaced all of the exhaust manifold bolts with studs.
donjetman
donjetman
Her's a good video on removing a 6L80 tranny from a 2011 Surburban 4x4
The guy in the video makes it look easy. It probably is if you have the right tools. I found out that I didn't. 1) My air racket was to weak to loosen the 15mm torque converter bolts that are locktite to the converter from the factory. Nothing else I own would do the job either. There not much room. So I went to HF and got a small 1/2" drive air racket(see picture-$115) and a ball and socket type universal joint(see picture-$8)
View media item 27405In the video notice how difficult is is to get to all the upper bell housing bolts/nuts. It's gonna be near impossible to get them back on :(
The ones on my 4l60 were hard to get to also, I used about a 4’ entension. If you tilt the engine as far as possible it helps.
donjetman
donjetman
Erickk120
I really hope doorman rear main seals are as good as fel pro or better. I would cry having to do it twice, I said never to doorman seals after having to do my pinion seal and having it leak on me a week later, could have been a fluke but I was scarred for life after having to do it twice. I made sure to never repeat that mistake and bought me a Yukon seal, Haven't had a problem since.
donjetman
donjetman
Eric, anything is better than what GM put in there.
I got the oil pan cleaned up and painted and ready to reinstall. Installed a new oil cooler adapter gasket Felpro#72462, a new oil pump pickup tube o-ring Felpro# 72401, a oil pressure relief valve deflector GM# 24237531, oil pan gasket GM# 12612350, and Dorman# 635-518 rean main seal kit.
While I'm there, I'm gonna change the tranny pump seal that the torque converter snout goes thru GM# 24237531.
View media item 27429View media item 27428
GM OE is quality, so I don’t know why you’d say that. Personally, Dorman has its place in my book but not for anything that’s difficult to get to. The quality of that brand is not great. If it’s not too late, I highly recommend using any brand other than Dorman for something as critical as a rear main seal. I’d sure hate to see that leaking again in a few months considering all the work it takes to get to it. I made sure to use AC Delco when I did mine. The original lasted 150,000 miles and still wasn’t leaking when I replaced it.
Erickk120
How hard was it to take the tranny out? You are motivating to do mine, I just hate the idea of getting the transfer case and tranny out, I have all the seals and what not, I just need to find my will.
Drewphil
