Neat lowering idea....
Badluck
SE WI
room to do it front mounted? If youre going that low your gas tank is gonna be in the way like.. NOW.. Part of having a pan hard. is when you tuck it shifting back and forth can cause issues.. some people are only tucking with 1/16 of an inch clearance on each side.. and thats too little to compensate for panhard slide when it lifts back up
Shit, you're right. I was looking at the passenger side and forgot about the gas tank.
MOBmentality
MOBmentality
Has a $25,000 Punch
leaks?
I don't understand.
a watts uses the existing rearend housing bolts to hold it on.. and i have heard the constant pressure and vibration will cause the rear end to leak around the bolt holes
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
it doesn't HAVE to use them.
you can run mounts off the housing
MOBmentality
MOBmentality
Has a $25,000 Punch
ahhh .. i had just always seen the bolt on..
Yea a watts kit could DEF let you do a rear mount spring
THats the perfect missing link
briannorris
