having a problem need some help!
c23tate
louisville
i have just bought an 06 tahoe and it is hesitating a little bit when i take off.also the lights dim a little bit also. i also have noticed that on my dash it says traction active? can somebody help? thanks
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
you need to check the voltage... could be as simple as a failing alternator or battery.
C
c23tate
louisville
re: hesitation
thanks alot i thought maybe that might the problem. i just wanted to see if anybody else might know. thanks alot for the qiuck response.
NOPROBROBB
UTAH
+1, that was going to be my recomendation, had a very similar experience with my jeep, after a new battery life was good, hope its a simple fix for ya.
puckhead
CO
Also, if/when you do replace the battery and you have some extras like a stereo set up I might recommend the Big 3 wire upgrade.
dizhai
