Stabilitrac issue after new rear brake lines were installed, theory correct?
jimweis
Lancaster, PA
Lines were installed by a shop summer of 2017. I found last winter the thing was near helpless in the snow, the stabilitrac would kick in making noise when just on light throttle. Previously it would kick in and go. I'm suspecting the brake lines were switched when replaced, right on left, left on right, the system is actually putting the brakes on the wheel with traction thinking it's the one spinning defeating the purpose.
I have been unable to follow the lines from the pump since they all but disappear over the frame and to the rear. I pushed it bit hard one time up a slight incline when it was slippery and it wanted to throw the rear to one side and off the road, surly not stabilitrac!
Is my theory correct?
Been dealing with the shop for 30+ years I want to offer to pay to make it right I just hate to point the finger. Lord knows what could happen if I need to panic stop on a wet road, fortunately that hasn't happened.
Scottydoggs
NJ
id get it scanned with a abs scanner. other wise your guessing.
the line swap deal, dont think so.
jimweis
jimweis
Lancaster, PA
My code reader shows no codes for ABS, the light has never come on while driving. If all sensors are good and the lines are switched how would it set a code, under power one of the rear wheels continues to slip on ice without the braking it would normally have to gain traction.
jimweis
jimweis
Lancaster, PA
I really expected some help here:( I finally decided on a snowy weekend to switch the rear lines and see what happens. All works as it should now. I couldn't find any shops with a tech 2 other than a steelership, so I took a stab at switching without confirming first.
afpj
Where did you do the switch, I assume at the abs module?
ya without a tech tool to activate the system and visually see what is happening then I don't think anyone could have provided anymore information on here for you and if that corrected the problem then clearly the shop screwed it up.
adriver
Glad you got it fixed. Are you able to post a picture of it, and we might be able to confirm or deny?
jimweis
jimweis
Lancaster, PA
I switched the lines at the cross member where the hoses connect then go down to the diff. I'm sure that's where they got things switched up.
jimweis
jimweis
Lancaster, PA
I expected someone would agree with my theory, the second post answer wasn't helping me,
"id get it scanned with a abs scanner. other wise your guessing.
the line swap deal, dont think so."
The line swap deal was so...
afpj
Jim,
I’ve been lurking on this forum nearly as long as you have, and I’ve never seen this scenario described before. Nice to be able to prove that your theory’s correct no matter how unique. I don’t have stabilitrack on the 02 so I think my rear brake lines are different. I thought when I changed to braided stainless a couple years ago that I had one line going to the back then it splits above the spare to the 2 corners. Can’t really swap that accidentally
Glad you figured it out
jimweis
jimweis
Lancaster, PA
Jim,
I learned more than I wanted to with this, the 4WD Tahoe only has one rear port out of the ABS unit the AWD system has two. The AWD system is absolutely helpless with out the ABS system applying brakes to the slipping wheel. The system has 3 open differentials front, rear & center. When one wheel spins without the assist the other three just sit still. This is why I suspected my lines were switched, it was helpless on the snow. Without Stabilitrac you get a limited slip or locking differential in the rear and clutches in the transfer case to transfer the power.
I purchased mine used in 2009 from a Chevy dealer, they said they had never seen another AWD Tahoe. This High-Low no clutch Borg Warner transfer case resides in Hummers.
Drewphil
