Convert manual to power side mirrors?
wendal
wendal
Dallas
Back from the dead.
So I busted my driver side mirror on my PPV and I'm debating going with the power fold mirrors. Just to reiterate, I need the DL3 mirror and a USED switch to make it work??
Yes, either a used switch or you will need to have the switch / BCM programmed at the dealer, as I did. I'm not sure if the programming will be necessary with a used switch or not, as mine was new. @NathanJax states that a used switch should work immediately. Also, I would go with OEM mirrors. As someone stated previously, go with OEM mirrors. The aftermarkets are trash. I ended up replacing my Dormans with OEMS after I broke one trying to install it...
Kee Fuller
las vegas
Anybody who has went to the dealership to have their switches reprogrammed. About how much did it run you?
Kee Fuller
las vegas
Update. I went to the junkyard and purchased 2 switches from 2 different escalades.
The good
The powerfolding feature works.
The bad
The turn signals in the mirrors still don't work
The passenger window doesn't roll down from the passenger switch
The driver window or the passenger window doesn't roll down the the driver side switch.
wendal
wendal
Dallas
The good
The bad
You'll probably need to go to a dealer and have the switches / bcm programmed...
Da90
Tulsa, OK
My experience was the signals always were plug and play. The switches had to be programmed to get other functions to work. If you were closer to me I have a buddy that does this stuff on the side.
Kee Fuller
las vegas
update, dealership had no idea on what i was talking about. They were talking about rewiring and other stuff. Im getting a headache over this.
GranPrix
You would need to talk to one of the techs/mechanics. The folks at the service area have no idea.
Kee Fuller
las vegas
Well got a used set of front switches from a escalade.
Mirrors fold, back windows roll down. But passsnger or driver rolls down.
Im going to try another dealership to see if they know how to program.
Kee Fuller
las vegas
This is exhausting and frustrating.
Dropped my truck off at the dealership and told them The 2 front windows don't roll down needs to be reprogrammed. My warranty covers replacement, but they will only replace the non folding original switches.
The escalade switches are different. When you turn on the parking lights. Those switches are white compared to the Tahoe are green.
They are going to flash the switches, if that doesn't work. I'm out of ideas.
Kee Fuller
las vegas
Update. Went to the junkyard today and found a yukon passenger side switch. It works. Passenger side window rolls down. Power folding works. Now gotta wait for the driver side to come in. Pray it works
vsaravia
