mountie
The tail lights are distributed by, K2 Motor ( ebay).... Lenses made by 'SPEC-D Tuning' ( ww SPECDTUNING. com.) ... ( About $65 bucks)......
Used / painted black -Esky vents bought for $80.... + $20 shipped.....
Here's a close view of the vent cover, different curve at the top, verses the original cover.... dosen't match the curve of my Yukon's curve...... but, unless you didn't know, you don't really notice. No one has ever mentioned the difference of shape, or if one year was different than another.
Mine aren't like that. Are both the same way?
KookyKoala
somewhere, IA
yeah mine had weird curve on it as well you can't hardly tell its there because its at the very top, once i went to esky 3rd break light it all matched again.
Pilot
Bloomfield, NJ * Lewes Beach, DE * Buenos Aires
Finally removed all the side molding and emblems from my Tahoe. It was really easy and I'm super happy with the results.
BEFORE
AFTER
BEFORE
AFTER
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
ArcticYukon
Dry Ridge, KY
These tires are pretty close at 32.6x10.7R18. No rubbing so far but I’m probably going to massage the inner fender plastic just to be sure.
Only time mine rub consistently is when I'm backing out of the driveway with the wheel turned. I need to trim the inner fender a little bit, but it's not anything critical. The only other time they rubbed was when I was on a road that was under construction and the lanes shifted right in the middle of the road turning, so the uneven pavement, speed I was traveling, and the curve made the suspension cycle just enough that the rear tire barely scuffed the upper fender well.
06JET
Wisconsin
So....installed a new steering cooler and as another member said, watch those cheap clamps that come with it. It was leaking at the cooler to rubber line connection. I found out that when I checked it with a screwdriver it was bound up on the screw drive of the clamp just before it was really tight. Very small leak. Had to use a ratchet and got it to tighten up. No more issues but I did have to take the grill and headlight out again to find and fix it.
View attachment 210436 View attachment 210437
Is it being used in conjunction with your factory cooler? Or is it deleted.
06JET
Wisconsin
Installed new fog/driving lights. Less than $30 for the set with bulbs. Took some Seal All glue and went around the housing to glass seal and over the little lens clip holes with 2 coats. Modified the bolt holes and used my heat gun to bend the mount so that the light fit the holes in the air dam. They look great. Now let's see how long they last. The last set make it 2 years before one was completely black inside because of water leaking in.
It is the factory cooler. I just replaced it. The old one was rusted and started leaking. I think it was $56 from Rock Auto.
Gotcha, thx. I ripped mine out due to leaking through the fins. Bypassed for now, tho I do have an aftermarket one to install. Think it's really necessary on our trucks?
NjA4207
