Window deflectors
Squirrelsmith
bought some weathertechs and the fit is garbage. the clips they want you to use to snap the back in are just a joke, they don't stick out past the weather stripping to clip the shield into.
anyone had any luck with anything else?
TigerEyz3
Slow and Steady
TN
I know this may be a bit late, but I've got WeatherTech in-channel deflectors... no problem with the clips holding them in, it's a press-fit.
Prior to the WeatherTech's, I had the AVS ones that tape to the metal/paint of the door above the windows.
Squirrelsmith
Squirrelsmith
take a pic sometime of the tab that holds in the rear end of your door deflector i'm curious
homesick
The Best Me I Can Be
Navy Air Force
Years ago, I had the style that fit into the window channel. They didn't let the windows slide all the way up, which caused a fairly bad wind noise.
joe
TigerEyz3
Slow and Steady
TN
These are all from the driver side...
20190107_164929.jpg 20190107_164944.jpg 20190107_164951.jpg 20190107_164955.jpg 20190107_164959.jpg
Wedge
I work at Autozone and have sold many a VENT visor. AVS is the best. The "in channel" ones have come a long ways, however the
"out of channel" with double sided tape is the most popular and work very well. As long as you prep the area well, as instructed, they won't come off. Good luck.
Auto Vent Shade - 4 pcs/smoked 94095 and sells for $59.99 here in MN.
Kelsda
New Jersey
The ones that go inside the window channel scratch up your windows about a quater to three eights of an inch (trash) on what ever comes in contact
JasonW4141
