My transmission came apart and I rebuilt the transmission in my spare bedroom with my daughters 1k miles since the rebuild.
Sent from my SM-N950U using Tapatalk
You sound like me, but it was Harleys in my spare living room lol.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Well we've been driving the old 'Hoe all summer with no issues. Cooler weather was coming our way, so I knew that meant it would drop to below 70* in the mornings and I was just waiting for the stupid REP to happen at startup... sure enough, Tuesday morning, it happened.
I had already ordered a new AC Delco replacement TPS but didn't have the time yet to install it. Finally after 3 mornings straight of it happening, my wife was fed up...
Installed the new TPS on Thursday afternoon before work.... the next morning, BOOM! Started right up with no issues. THANK GOD!
So now the only thing I need to worry about with that truck is cosmetic stuff.... well... that and the infamous ABS issue.
jarydM
Lost in the Woods
Tennessee
Been a busy month for the Tahoe I guess...
This morning just outside of Nashville at about 04:30 a deer ran out in front of the truck in a dead sprint, and I caught his head with the drivers side light assemblies.
I’m just gonna hope the insurance doesn’t seem this “totaled”View attachment 210075View attachment 210076View attachment 210077View attachment 210078I drove for 4 hours after that home. No damage to internals, but I’m afraid it bent the driver’s door too. Damn deer hit the side of the car so hard in a wraparound that it opened the door.
Update:
Radiator is definitely cracked, somewhere. Didn’t lose enough fluid for the temps to change in the 3+ hours of driving after the hit, but that significantly reduces the probability of getting to keep her.
:bawl:
So if anyone’s got a line on an 09-10 with a 6.2 in it, let me know.
Update:
:bawl:
That's a cheap fix, $100-$125.
HiHoeSilver
Away!
Chicago
Update:
:bawl:
:sad72:
Scottydoggs
NJ
picked up some spray adhesive to fix my head liner where its peeling off a bit.
did my regals failing spot first, worked perfect, so off tot he 05 silverado work truck, its got 4 inches hanging down across the whole windshield, talk about annoying right? hit that whole thing up and pressed it back up, looks 100X better. got home did my little area on the hoe.
dubyagee01
Mine is loose in the same spot and right in front of the passenger visor.
Scottydoggs
NJ
the can was 7 or 12 bucks iirc. or call it 10 ish lol money well spent. im sure ill find other uses for it down the road.
its just like rubber cement, spray it on let it dry then pull it up to the edge and press it down. i did hold some paper up to shield the rubber molding when spraying it.
That one isn't that great, the orange Permatex can holds better and lasts longer.
Keviebear86
What’s your setup? Rear coil spaced and leveling kit? 20x10’s? Sorry for all the questions lol
Stock rear coil springs with 3" Supreme Suspension spacers and ebay shock extenders. The truck rides great for the 10ply tires and the lift. I love it.
eand28
Pennsylvania
Slight thread jack...
So apparently GM finally decided to let customers get the 6.2 performance package in the suburban as part of the RST package. Didn't know why they didn't let you order one from the beginning.
Phlipnstik
