Window regulators- OEM or aftermarket?
I searched existing threads and found nothing directly comparing them.
Obviously, the CHEAP aftermarket ones are going to be more cheaply made and I'll avoid those. But it's also likely that the current AC Delco replacements have a few cut corners as well. They may even be totally outsourced by now and just be a decent aftermarket unit that AC Delco deemed sufficient to carry their label. My best bet is to find a NOS assembly and I'll look around for one. Is there a GOOD aftermarket brand I could consider? There's a company in Arizona that rebuilds original regulators with custom-machined metal parts so they're essentially bulletproof. I emailed them for info and price, but I doubt I'll dive down that wormhole since my original lasted 193K miles (well, I'm assuming it original) and I rarely drive the Tahoe now.
992dr
Eastern N.C.
After reading several bad reviews about aftermarket regulators, I went with OE.
Called my local dealer and they wanted my first born so I googled them and found one online for a lot less through a GM parts site.
I would check rockauto and just order a oem one, doubt you will find a cheaper price anywhere except ebay and even ebay is often very close but the catch with that is free shipping so ebay sometimes wins. it can go either way, sometimes amazon is mixed in there too
I'm with you guys- best bet is OEM, even if the newer revisions aren't quite as good as the original. Wes, I didn't see any new OEM ones that cheap on Amazon. I should double-check my search criteria.
On the other hand, this is being put on hold for now because I fixed it. Had a frayed cable all caught up on the drum. Took it apart and made a new cable with stuff I had laying around. Works great now. Will post pics and details in my build thread if anyone's interested.
Thank you for your replies.
992dr
Eastern N.C.
If I remember correctly, I paid about $120 for my assembly from GM.
I didn't know it was available without the motor. I'llbedamned. I'd probably get one with a new motor since mine is who-knows-how-old and it's always been a hair slower than the others.
Thanks for the info!
usually they are sold separately because normally only one or the other fails, more common for the regulator to fail than a motor
and when the regulator wears that is what makes it slower, when you replace it normally it ends up being the faster one then because the other 3 are now worn more. hence why the front windows will end up being slower then the rears because the fronts get used more often. same for drivers window versus passenger.
thompsoj22
Geeze, im impressed! cable driven window regulators freak me out when they get snarled and you brought one back from the dead!!
Thank ya! It was too easy of a repair to keep my door taken apart for a few days while I waited for a new regulator to be delivered.
After diving into this, I think what makes them slower is the grease gets wiped away sooner. Naturally, if a window is used more, the trolleys/carriers/whatever they're called sliding up and down will wipe the grease away faster. The self-lubricating properties of the plastic is then relied on to keep it from binding, but at the expense of the plastic wearing away. The extra slack from the worn carriers and plastic dragging on the guides puts extra stress on the motor, which eventually weakens it. My pulleys were in great shape and I didn't notice any excess wear on the plastic parts. I did notice, after I greased up everything, how much smoother it operated when testing it on the shop floor. The window seems to travel a little faster now. It's still a little slower than the others when going up, and I believe that's from an aged motor that's been pushing a frayed and dragging cable for so long.
I didn't have time yesterday, but I would've taken this opportunity to install sound deadener in the door while I had everything opened up. I'll definitely grease up the window tracks on all the doors when I install that deadener.
Cliffjrs
Picks one up at Advance Auto last January in Glens Falls NY. Put my LF window down to clear out cigarette smoke and it stayed there on a 20 degree day. Been happy with it. Like anything electrical on the Tahoe, eventually it will need replacement. GM sucks when it comes to electrical components.
dizhai
