Rough idle and no power when engine cold
Asfalto
Northern Italy
Hi everyone!
Here is the new issue on my 1998 tahoe 4dr 5,7 4x4:
when engine iscompletly cooled down, cranking takes more than normal and, after that, engine runs very rough (5 or 6 cylinders to me) with no power; sometimes it hardly move the truck, sometimes it stalls.
when hot it starts immediately and runs fine and smooth.
note:10 years ago i've installed an alternative fuel system (LPG: liquefied petroleum gas) on the truck, it is normal here in italy since the gas price is 7,16$ per gallon.
This gives me the opportunity to check the engine in the LPG mode and it runs fine at any engine temperature.
example: start on gasoline-->rough idle-->switch to LPG-->fine and smooth
This leads me to think that it's not an electrical or ecm problem but a fuel related problem.
What can cause this issue only when the engine is cooled down?
thank you
Asfalto
Asfalto
Northern Italy
Only on gasoline and when engine is cold (outside temperature 60 or more).
If i switch to LPG runs fine, if i switch back to gasoline it runs rough again.
This until engine warms up; then runs fine either gasoline or LPG.
thanks
HiHoeSilver
Away!
Chicago
thanks
Check your pressure at the rail. I'm guessing fuel pump.
k09viper
