Rough Country 7.5 lift Problems
scottbrew92
South AL
Had the same feeling with my Tahoe and the 7.5" lift I was even getting a traction control light in corners with a leaning feeling. I ordered and installed some "spherical" front sway bar links and really tightened everything up so make sure your front links are tight.
81malibu350
81malibu350
Long Island NY
Hi Guys.. I still haven't installed the pro comp brackets because i have been dealing with some other problems. i keep getting a check engine light with the codes of p2122 and p2138 i have changed the throttle body and the gas pedal and the connector on the tb.. Any help would be Appreciated!! Thanks
81malibu350
81malibu350
Long Island NY
Where did you get the end links from?
Lil_Stump
Brunswick, GA
Does anyone have the part number for the pro comp drop brackets? Or are they something id have to call and get special ordered seperately from their 6” kit?
01Konvict
Boats n Hoes
Raleigh/SML
You can order them from summit racing. Look up the kit instructions and get the part numbers. Or I posted them in a white burb thread that had the rough country 7.5 kit.
Arch
Findlay, OH
Thanks 01Konvict
I ordered the Pro Comp Rear bracket should have them Thursday. I have my fingers crossed that it fixes my problem..
Did them drop brackets solve the problem? I did the same thing but I'm not done with everything yet so it 's a week or so from being on the road.
Arch
Findlay, OH
Hey! Would you be able to link the bracket you bought? Mine snapped...
Thanks!
You can thank 01Konvict for this link . I just copied it from one of his responses helping one of the several members he's assisted including myself. I bought these brackets also.
Here are the pro comp drop brackets and hardware. See instructions link for install. Have to call and special order from summit. Part # 91-1785, 91-1790, 90-6276.
https://www.procompusa.com/aux_incl/pdf.ashx?pdf=51947B_K1141B_INST.pdf&line=EXP
81malibu350
81malibu350
Long Island NY
I know this has been a long time since I posted with my issue. But the brackets really didn't do much to help with the sway feeling. I think that time it self was the thing that helped because I got used to the feeling when I drive it..
Dustin Jackson
@81malibu350 I'm sorry to hear that man, are you not happy with it?
I am new to this thread but I don't see any mention of the track bar. The track bar is responsible for keeping your rear axle centered under the body of the truck. Has the track bar been addressed?
81malibu350
81malibu350
Long Island NY
Hey Dustin. No its not that I'm unhappy with them. I just didn't get any positive value from them. I don't think the panhard bar really plays any roll in this problem. I'm sure its 7.5 lift and 35 inch tire are the real culprit when it was stock it rode incredible now its a different kind of incredible.
brice715
