Rough Ride Bulletin
Reels
Senior Member
Not sure if this has been posted before so sorry if it has.
Document ID: 4204876
#PIT5429: Rough Harsh Ride - (Jun 1, 2015)
Subject: Rough Harsh Ride
Models: 2015 Cadillac Escalade Models
2015 Chevrolet Tahoe LTZ, Suburban LTZ
2015 GMC Yukon Denali Models
With Magnetic Ride Control Suspension (RPO Z95)
Vehicles Built Before 2/10/2015
Attention: Installing the updated suspension components and calibration call out in this PI will NOT provide a ‘sofa-on-wheels’ type of ride, and will NOT eliminate tire/wheel, propshaft, rear axle related inputs/disturbances; they are designed specifically to address the rough, harsh rough/harsh/stiff ride concern.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
The new 2015 Full-Size Utilities incorporate suspension design improvements for improved handling, decreased stopping distances, reduce body roll, etc. Many customers are very satisfied with the ride and handling, but some owners may feel the ride is not to their satisfaction. They may comment of a rough/harsh/stiff ride, or they may describe a vehicle vibration with a similar description.
Typically, this condition is most noticeable between 35-55 mph on fairly smooth roads, when coming in contact with small/minor road imperfections/bumps, expansion joints, etc. The suspension will absorb larger bumps without complaints, but smaller/minor imperfections/bumps, which would normally be absorbed by the suspension, may not be absorbed as well as the owner would expect.
Recommendation/Instructions
Evaluate the vehicle using the vibration analyzer CH-51450-A (Pico Oscilloscope), driving the vehicle in 35-55 mph range on the same section of road for each stage of evaluation. Pico scope will normally show this ride condition as a Tire 2 or Unknown vibration (approximately 15-19 Hz) in response to small/minor road imperfections/bumps. The vibration analyzer should be used twice: 1st to determine the customer concern is a rough/harsh/stiff ride and 2nd after the repairs to verify the cause is repaired and to identify if other inputs / disturbances are present. The Hz and Mg readings should be documented using the Z95 rough/harsh/stiff ride / vibration chart below.
Important: When using the vibration analyzer make sure to obtain readings after the vehicle has been driven at least 10-15 miles to warm up the tires and cycle the new shocks. After new shocks are installed they will need to be cycled before optimum ride is obtained, which is done during normal driving.
[During evaluation, position the Pico accelerometer sensor to capture Both vertical and horizontal planes, for tri-axis sensor, ensure correct orientation for X, Y, and Z axis. Place the sensor on the seat track, console (avoid wireless charging mat), steering column, etc. If additional sensors are used, place at each vehicle corner to help narrow area of strongest input/disturbance.]
Z95 MR Rough/Harsh/Stiff Ride / Vibration Worksheet
Road Condition
Small/minor road imperfections/bumps, expansion joints, etc.
Speed Condition Occurs
35-55 MPH (55-90 KPH)
Pico Scope Readings Before Any Repairs
Sensor Mounted Vertical or Y plane at Drivers Seat Rail:
Sensor Mounted Horizontal or Z plane at Drivers Seat Rail:
MPH/KPH:__________ Hz:__________ m/g's:__________
Sensor Mounted Vertical or Y plane at _____________:
Sensor Mounted Horizontal or Z plane at ___________:
Pico Scope Readings After Repairs
NOTE: Ensure vehicle is driven 10-15 miles to warm the tires and cycle the new shocks
If a rough/harsh/stiff ride has been determined to be the customer’s concern, following evaluation using the Pico scope, then replace the complete front suspension shock with coil spring assemblies, and rear shocks with updated parts and reprogram the Suspension Control Module (K19) with updated calibrations available in TIS2WEB. (The calibration may be labeled "Real Time Damping.”) The updated part numbers listed below utilize various improvements to address the ride concern as described.
Note: Vehicle alignment does not need to be adjusted as a result of the Z95 MR suspension component updates.
Please note that this rough/harsh/stiff ride / vibration condition can be magnified by other inputs/disturbances which may be present, such as: Tire and wheel assemblies with excessive road force variation (RFV), propshaft balance / runout, and/or rear axle pitchline runout related issues. These updated suspension components will Not correct these other inputs/disturbances, which Must be addressed separately. If an issue in any of these other areas is found, it should be corrected Before returning the vehicle to the customer, See the latest version of PI1354 to work through other inputs/disturbances.
Following Z95 MR-related updates, re-evaluate the vehicle to ensure no other inputs/disturbances are present. If other inputs/disturbances are present, review the additional diagnostic tips in this PI and correct the remaining conditions:
– Tire and Wheel Assemblies
– Propeller Shaft
– Rear Drive Axle
Additional Diagnostic Tips -Tire and Wheel Assemblies
Ensure tire and wheel assemblies are not contributing to the issue. Keep in mind this rough ride issue will often show up as T2 in response to road input, (suspension reacting to road input, rather than absorbing it). If T1 is present, or any higher order, other than some T2 in direct-response to road input, expansion joints, etc. the tire and wheel assemblies must be investigated. There have been some cases of T2 tire issues, some high-speed RFV issues (primarily with the 22-inch Bridgestone tires), and some cases of tire/wheel assemblies showing acceptable RFV numbers, but with further investigation, have been found to have bent inboard rim flanges with hidden tire damage, visible inside when dismounted.
The GSP9700 checks tire low-speed RFV only, in the radial plane only
Object ID: 4204906Click here for detailed picture of the image.
The GSP9700 is set to display T1 RFV. Higher order RFV, T2 & T3 can be displayed in the Assembly Data Plots Screen, as shown above. Depending on the level of GSP9700, the screen may be under ‘Data’ or ‘Runout Plots,’ then “Rim and Load Roller Runout Plots.”
When checking tires on the GSP9700, if (radial) T2 is high or close to the (radial) T1 value, the tire should be replaced. As an example, if a tire and wheel assembly is measuring T1 at 10 lbs RFV, the tire would be considered good; however, if in displaying the higher orders, it is found that the tire and wheel assembly also has T2 at say 9 lbs RFV, the tire needs to be replaced. Refer to the latest version of PI1354 for latest procedures.
Road Force Variation (RFV) Specification to Address Ride Concerns
P-Metric Tires on Light Trucks, SUVs
15 lbs (6.8 kg) or Less
NOTE: Arrange the tires on the vehicle in the following order: lowest RFV at LF, next RF, next LR, highest RR
-Propeller Shaft
Ensure the propshaft is not contributing to the issue. If any orders of P measured with significance on the Pico in vertical or horizontal planes – inspect the propshaft for dents or other damage. If no damage is present, check propshaft balance and runout, refer to the latest version of PI1354 for latest procedures. Remember to consider and inspect the transmission output shaft bushing for irregular wear.
-Rear Drive Axle
Ensure the rear drive axle is not contributing to the issue. Pitchline runout / gear set machining, followed by setup issues have been found to be contributors to vibration issues; not just whine noise concerns.Gear set machining issues in these axles seem to most often show up as P1 or higher order P related; with some showing as T1 or higher order of T related; all depending on gear set condition.
If tire/wheel assemblies and propshaft have been ruled out / repaired, and P1, T1 or a higher order of P or T is still present in the vertical or horizontal plane – other than in direct-response to road input, the drive axle must be investigated
Check for pitchline runout and setup issues, refer to the latest version of PI1354 for latest procedures.
If drive axle repair is necessary, we have heard some reports that during repair, tooling chatter marks may be observed in the pinion race counterbores. This issue lends to the idea that the races may not be fully seated until some vehicle use is introduced into the axle. This issue would most often result in a noise concern, though severe loss of preload might produce a vibration. The races should be able to be fully seated during repair
Parts Information
Part Number
Description
Vehicle Model
Spring Code
Qty
Front
Note: Verify spring code RPOs, LH and RH for vehicle from the SPID label or IVH/GWM. Some vehicles by-design will have LH / RH spring codes which fall into different groupings / different part numbers for each side – they must be serviced in the same manner to best address this ride concern. For example: A truck with LH spring code of 6ZS, with RH spring code of 7ZR would use 23312158 for the Left side and 23312157 for the Right side.
23312152
Spring Asm-Frt Coil (w/ Shock)
C157 06
6YR, 7YR, 6HD, 7HD
1 side
23312153
C157 06
6ZC, 7ZC, 6HF, 7HF
1 side
23312154
C159 06, K157 06
6ZD, 7ZD, 6H3, 7H3
1 side
23312155
C159 06, K157 06
6ZN, 7ZN, 6H4, 7H4
1 side
23312156
C159 06, K157 06
6ZP, 7ZP, 6JU, 7JU
1 side
23312157
K159 06
6ZR, 7ZR, 6XF, 7XF
1 side
23312158
K159 06
6ZS, 7ZS, 6XH, 7XH
1 side
Rear
23267007
Absorber Asm-Rr Lvlg Shock
ALL
ALL
1 Side
Warranty Information
For vehicles repaired under warranty use:
Labor Operation
Description
Labor Time
8080158*
Replace Both Front Coil Spring/Shocks, Replace Both Rear Shocks and Reprogram Suspension Control Module Programming
3.5 hr**
* This is an unique labor operation for bulletin use only. This will not be published in the Labor Time Guide.
** This includes Before and After PICO Scope Diagnosis
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Chevyzoomina
Hello, I'm having these issues with my ltz, has anyone gone to the dealer and actually got them to perform these fixes?
Reels
Reels
Senior Member
Parts are on order for mine. Had the test done with the pico meter and sent in. I'll report in a week or two once they change them out.
Reels
Reels
Senior Member
No, not at all. I had to provide the bulletin information for them though.
They just received the pico scope and had to go to training on how to use before they could do my ride so that delayed things a few weeks.
Once they gave GM the vibration data, GM authorized the parts.
Reels
Reels
Senior Member
Had the mod done. Difference is night and day. She drives like a Cadillac now.
Chevyzoomina
I went for an oil change and couldnt leave the truck too long so I had them update the suspension software. Rode good for a couple of days, now I'm feeling a vibration. They said if it still wasnt good they would do the full replacement, just need to find the time to be without the truck for a few days.
plasticman
Condition/Concern
Road Condition
– Propeller Shaft
– Rear Drive Axle
-Propeller Shaft
-Rear Drive Axle
Parts Information
Part Number
Description
Vehicle Model
Spring Code
Qty
Front
23312152
C157 06
6YR, 7YR, 6HD, 7HD
1 side
23312153
C157 06
6ZC, 7ZC, 6HF, 7HF
1 side
23312154
C159 06, K157 06
6ZD, 7ZD, 6H3, 7H3
1 side
23312155
C159 06, K157 06
6ZN, 7ZN, 6H4, 7H4
1 side
23312156
C159 06, K157 06
6ZP, 7ZP, 6JU, 7JU
1 side
23312157
K159 06
6ZR, 7ZR, 6XF, 7XF
1 side
23312158
K159 06
6ZS, 7ZS, 6XH, 7XH
1 side
Rear
23267007
ALL
ALL
1 Side
Labor Operation
Description
Labor Time
8080158*
3.5 hr**
My Denali has been lowered with dropped spindles, if I took it in would they tell me tuff shit!!!!
donn
How can I confirm the PIT 5429 TSB was performed? I have a 2015 Tahoe LTZ that rides like a covered wagon. This repair was done but it had no effect on my Tahoe. I'm beginning to think the dealer might have made a mistake. Also seems like a lot of work for 3.5hr labor.
formula271
Have others had this repair performed?
This TSB doesn't apply to my 7/9/2015 build 2015 Suburban LTZ w/MRC. But, my vehicle rides so poorly, I can't imagine how bad the pre-2/10/2015 vehicles must be. Does anyone know if the strut/spring p/n's have been updated since this TSB was published?
donn
Yes I have had the TSB PT 2459 completed and it made no difference. After about $3,000.00 I finally found a solution to the rough ride on my 2015 Tahoe LTZ. Contact http://www.xineering.com/shocksims.html. They've developed simulators that allow you to replace the shocks with quality aftermarkets like Bilstein. They offer both a full kit for $425.00 and a half kit for $260.00. If you have the same Tahoe as I do then buy the half kit for the front. I tried the full kit replaceing the rear shocks with AC Delco air shocks but It didn't work out. Service suspension and Park Assist, Driver Asist messages came on the DIC. So I reinstalled the factory MagRide shocks on the rear and used the ride height and shock simulators only on the front. The ride is much better and if I had just bought the half kit simulators and Bilsteins for the front and left the rear alone I would have only spent $260.00 for the 2 shock and 2 ride height simulators and $300.00 for the front shocks. I understand Arnott is close to coming out with rear air shocks for this application that have built in simulators.
plasticman
Is the ride $600.00 better????
justinakay79
