Shake it up
Massfloefi
Massfloefi
Replaced all the body mounts and radiator mounts. So far it's main benefit is the ease in which the doors and hood close. I think some body roll was eliminated but need more time behind the wheel to confirm. As of this moment I don't feel a change in ride comfort. Maybe there will be a change after they break in. I will post back.
Massfloefi
Massfloefi
Just a comparison of old vs new mounts.
Massfloefi
Massfloefi
When I felt no change to the ride quality after replacing the body mounts I started to think again about my problem. Dampening. So I applied ample pressure to the front end to see how the shocks rebounded. There was very little movement. I did this with two people so I know I had a problem.
What did help the ride quality was raising the torsion bars by four turns. When I pushed down on the front end this time the truck felt less stiff and more fluid in its movement. I wouldn't say leaps and bounds but better. The jouncers now look like they are just touching the lower control arms. I didn't think it did much at first (I raised them without supporting the vehicle) but after a 30 mile trip I believe they adjusted and I have never had a better ride on the FDR. Anyone around here can attest to what kind of junk road that is.
I need more time behind the wheel to confirm this. The ride isn't perfect but a improvement is more then welcome right now. I will update later.
Massfloefi
Massfloefi
I was pretty frustrated after changing the mounts and feeling no difference in the ride quality. So I went ahead and purchased another set of front shocks. KYB Excel-G 344381. They are a twin tube design so they should be softer and based on customers reviews most are generally happy with them. Plus the price was right.
I currently have ACDelco OEM monotube shocks installed. They were pretty stiff when I tried to compress them by hand initially especially compared to the Bilstein's I removed. I am no shock expert so I am not sure how that affects their dampening ability.
I haven't decided to give them a try just yet after the success I have had with adjusting the torsion bars. I will update when I do.
MrBalll
West Texas
This sucks. Sorry to hear mounts didn't help.
Will be patiently waiting on info for your new shocks.
Massfloefi
Massfloefi
So far adjusting the torsion bar has made the biggest difference. I am not constantly cringing when I am about to hit a pothole.
This week I am going to tackle the torsion bar crossmember bushings.
Massfloefi
Massfloefi
Any updates? I'm curious to know what it is.
I replaced the torsion bar crossmember bushings. No change. Something is loose. Can't figure it out. Was thinking about new torsion bars but that may be a waste of $450 and I may go full coil over from Atomic.
Massfloefi
Massfloefi
Changed the front shocks to the KYB's and I am happier about the comfort/dampening they provide. I could tell that there would be an improvement after pushing down on the front end to test the shock give. The OEM fronts had no give at all unless I stood on the bumper and jumped up and down. I would guess they will continue to improve after breaking in.
Recent parts changed:
Steering gear
Inner/outer tie rods
Manifold exhaust leak fixed:
Dorman manifold clamp
Steering gear
How about the rears? How do they feel?
Massfloefi
Massfloefi
Ran out of daylight when I replaced the fronts. Wasn't sure I should change the rear shocks for load reasons. I'll update if I change them.
Ran out of daylight when I replacement the fronts. Wasn't sure I should change the rear shocks for load reasons. I'll update if I change them.
Not sure because I'm lowered or if the rear shocks are too soft, but I hit the rear bump stops often.
brice715
