Opening rear hatch when battery is completely dead?
Eric2016LTZ
I don't currently have this problem, but it just occurred to me. Can you open the rear hatch in the absence of battery power?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Unless there an access cover on the rear panel so you can access the latch, I don’t think so. You could however put a portable jump pack on the terminals and operate it that way
Eric2016LTZ
Eric2016LTZ
Thanks for your reply. I was afraid of that. I store "emergency supplies" in a locker in the rear. Ironically, a jump pack is one of those items. Guess I need to keep one in the forward cabin from now on.
dbbd1
Can't you just turn the knob to manual and open it by hand? I always open mine manually.
Edit-you must mean unlocking it
Eric2016LTZ
Eric2016LTZ
I guess I mean both unlock and open. However, I don't have a knob, just the button on the inside of the hatch handle, which I believe takes power to actuate.
only option I can think of is to take the inside panel off and attach some kind of emergency pull cable, drill a hole in the panel push the cable thru the hole and attach a pull ring to it, at least that way you could open it from the inside if necessary, similar to what they put inside car trunks now.
dbbd1
Okay, are you talking about the glass panel or the whole hatch? I have a switch on my overhead console that I can select between manual-3/4 open-full open for the whole hatch.
Yeah, unlocking would be a bee-yatch with a dead battery. I'd be curious to see at what voltage it quits working. The cable thing to unlatch it is about the only thing, that I can see. Short of keeping a little "battery jumper" battery up front, as said previously.
Eric2016LTZ
Eric2016LTZ
I was referring to the whole hatch. I like Doubeleive's idea of the DIY cable release. I know it may seem paranoid, but I hate being at the mercy of electronics to gain access to my gear.
Floep
If you look at the inside panel in the location of the latch, you will see a little bump in the plastic panel. care fully DRILL A 1/8 LOCATING HOLE in the bump, enlarge it to 5/8" and you will find the lever rod that unlocks it, get a 5/8 plug to close the hole. Use your ingenuity to make a pull attached to the link or leave it plugged.
dbbd1
Nice! I'll have to check that out.
Thanks.
Conedaddy
