Black Widow exhaust
09_4WD_YUKON
Looking to add a Black Widow Venom 300 muffler to the Yukon. The orientation should not matter, correct? The new muffler is about 1/2 the length (if not more) than the stocker, so there should be more than enough room to make any transition or positioning, correct?
sarneson91
Alexandria, VA
Should be fine either way, I believe mine had an offset inlet/outlet and then a short piece of tubing to connect it back to the stock exhuast tubing.
09_4WD_YUKON
09_4WD_YUKON
Got any sound clips of your exhaust?
sarneson91
Alexandria, VA
Not right now, I'm on deployment otherwise I'd grab you one. There's a Black Widow thread that has some good clips in it, I have the race venom with the resonator delete and a single tip at a 45 out the back.
09_4WD_YUKON
09_4WD_YUKON
Thank you for your service!!
Yeah, I have been through that thread once or twice, but never have found the clip I'm looking for....Venom 300 with resonator delete.
Towmaster
