ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Idk man if you see a can on the side of the road it gets pretty faded I think a set of HIDs blasting on it for a long time would fade it out real quick hi heat paint would work best
True, but it's the UV rays that do the fading, not just the heat. I think it would hold up much longer than sitting in the sun, personally.
05Single
afraid of the dark
I’m gonna just use some high heat engine enamel when I do it. They’ve got lots of colors online
None that ship to me, hazmat lol. I only have a few to select from locally. Idk just thinking outside the box, these will be facing away from the hid bulb. Towards the lens so I think theyll be fine:shrug:
Bombsquad85
Northern VA
It feels like I'm at the same spot i was weeks ago but 3 wheels clear coated and waiting to cure 1 wheel untouched ugh..... looking at it makes me tired so much sanding to get chrome able to hold paint
Scottydoggs
NJ
picked up push pin clips to mount the fender flares with, got one on after work. took bout a 1/2 hr being i had to drill the holes. lucky for me the 05 work truck has flares and i pulled one pin to figure how large the hole should be, then a bit of masking tape where the holes are, then marked and then drilled.
the rest will go faster. learning curve as always.
this is wet sanded. im mounting them to be able to buff em out better/easier.
and im going with nailed the color!!!!!!
im going out of my way to get the rest mounted now. im liking this look so much better. makes it not look like a 1500 lol
Def nailed the color- where'd you get the paint? Automotivetouchup?
Scottydoggs
NJ
went with this place. https://repaintsupply.com/ its by paint code, reviews were good. also they sell a larger can by like 5-6 oz's for the same price as many other brands. iirc it was 21 a can. bought 4 cans used 3 got 3 coats, then i got one can of clear, got two good coats out that. wish i got another can really.
i want to paint the chrome part of the grill red next, was hoping id have enough, but no way one cans gonna cut it. so ill order up anther can and one more of the clear and get on that over summer.
Escalade2007
