Stock torsion key movement
95escahoe
I’ve got an 04 Escalade I’m going to most likely ditch the Autoride on and go with a 2” lowering spring in the rear to level it out, the front will sit a 1/2 higher to the stock torsion keys have enough movement to correct that? Or will I need new keys too?
cmc76
I believe you can get a little adjustment in the stock keys. I put 2" drop springs on my tahoe .Need to get back under it for keys.
95escahoe
95escahoe
What springs did you use?
cmc76
I bought them used. But I think they are bell tech. Though if I had to guess, i think I got more than -2
95escahoe
95escahoe
The only Belltech drop springs I’ve seen are 3” or more
cmc76
A guy I met had them on his tahoe. He wanted to go up. Me down. I never did much research. I like how it sits. But the front should drop a hair .Ill get a pic once rain stops
95escahoe
95escahoe
Thanks if I did a 3” drop I’d definitely need new keys that might be the look I’m going for
cmc76
I'm pretty close to level as it sits. Ill take a pic today though
cmc76
This is the springs in back. Haven't touched the keys. Ill take more pics when the 24s go on Saturday.
AdrienR
