TheAutumnWind
Kept finding my coolant reservoir empty. Started noticing that there was more fluid under the truck after startup then I would expect from the a/c system. Finally came to the conclusion that the coolant reservoir cap must be bad even though it looked fine visually.
Replaced it and no more leaks.
I had almost the exact same problem, besides losing coolant, the system was pressurizing. Weird that it never over heated. I replaced my cap and it was all good.
TheAutumnWind
Yeah same here. Never noticed it overheat, seemed to hold pressure. I think the pressure spike @ startup was causing it to blow past the seal or something.
M1Gunner
Gainesville, Fl
Installed my bixenon projector fog lights with 5000k H11 hids.
Fogs only (no headlights)
Fogs high beam only (still no headlights):eek:
Low
High
Shadows with projectors trip me out lol. So sharp and crisp View attachment 199599
I pity th:893MrT-thumb:whoever flashes me on the road
My new favorite mod:Big Laugh:
Sooo, fill us in, you know we need some details. How much and where from and all the juicy gossip!
Devilmk4
Picking this up tomorrow. Am becoming a gmc *****. Supposebly has a blown motor didn’t try to start i will swap the motor if needed.
dszx13
Are these worth it? My nnbs I used a relay.
Sent from my SM-G928V using Tapatalk
05Single
afraid of the dark
I just bought 2 of them off the fleece website for $20 each. Up to you and if you like a chip better. It's definitely a cleaner install
Keep in mind it only works when the high beams are on. If you want full time fogs or DRL you need to do the mods and if you have the module you can't do that.
dszx13
I did more research and found the part numbers to the diodes. For less than 3 bucks I'll try it lol.
Ftrsavage
Pittsburgh Pa
Code:
https://ibb.co/d0TiVo
https://ibb.co/m1AK38
https://ibb.co/h4Nz38
https://ibb.co/m7QK38
https://ibb.co/hmrsO8
https://ibb.co/j78BGT
https://ibb.co/jkXtVo
https://ibb.co/eXShO8
https://ibb.co/fCop38
https://ibb.co/k7Pwi8
https://ibb.co/feT0Ao
https://ibb.co/it8NO8
https://ibb.co/kOuU38
https://ibb.co/btTp38
https://ibb.co/cQNhO8
ASG-MikeS
