Common problems? 2000-06
Yukonjoe2001
I'm parting out an 01 Tahoe and would like to know what parts I should hang on to for my 01 yukon.What are the weak points or common issues of the NBS Tahoe/Yukon/escalade? Besides the trans. I don't wanna keep parts I my never use. I also plan on buying a fixer upper extended cab truck that can share parts from the Tahoe as well. Would it be worth pulling the rear end?steering column?do the dashes ever crack on these trucks?
Engine, transmission, differentials, transfer case, calipers, steering box, abs module if it matches yours 100%, instrument cluster, rear view mirror, 4wd switch, probably something else I'm missing, but it all depends on how long your going to keep your other truck going
Yukonjoe2001
Yukonjoe2001
I've never seen a cracked dash either. my Yukon is 2 wheel,will the 4 wheel drive brake parts interchange with 2 wheel drive?
I'm 99% sure the calipers would be identical, but you can verify that on any autoparts website by looking up calipers for both 2wd and 4wd
Erickk120
You guys forgot to add the driver seat foam and cover, Obviously that is what fails right.
05alive
Masshole
Interior parts, those sell for decent money if they work and have paint intact.
Switches, and the lights in them especially, die all the time. Sems like every time I get in, another light's out.
Durobans
