Really bad driver side water leak: carpet soaked
jyi786
Hey all, I was turned onto this issue a few weeks ago and I've been struggling with it since. I could definitely use some suggestions here.
2012 Yukon Denali XL. I had kept noticing a spot of water on the driver's side carpet. When I was cleaning up the car, I took the mat out and found that the carpet was soaked. I mopped it up and thought it was from my shoe being wet. After a few more days, the carpet was still wet. I started doing research and found that this issue might be worse than I thought, so I started running through the complete battery of tests. Here's what I found and what I did so far.
1. First thing I suspected was the sunroof drain holes. I tested them, and they are free and clear. They drain properly down the vehicle. There are no water stains whatsoever in the interior headliner, so this leads me to believe that's not it.
2. I ordered and installed a brand new door weatherstrip. The old one was beat up pretty bad.
3. While installing the new weatherstrip, I took the time to get the carpet up and the padding. They were completely soaked, as well as the firewall. I spent the entire afternoon drying it out, made sure the new weatherstrip was installed properly, then put everything back together.
4. This was the place of interest. The kickpanel on the side of the driver's door where the fuses are located? It had clear evidence of water splashes (you could tell from the rust). The leak has to be coming from around this area. I stuck a dry piece of paper towel in this area as a test, just to see if I would get wet.
5. I tested with a bottle of water, pouring it down the side of the vehicle. Seemed to work ok, with nothing getting wet.
Forward to now. Today and for the next few days, there is a massive rain/snowstorm. It was raining overnight heavily. This morning I hop into my truck to go to work, look down, and what do you know: the damned carpet is SOAKED again.
When I get to work, I open the side driver's kickpanel; the papertowel has been completely soaked, and it is soaked inside there, as well, water getting all over the electrical connections, leaking down the cowl piece, and soaking the carpet.
This moldy carpet is the reason I got dead sick the past 2 years. I'd like to stop this water leak completely. Any ideas on what this issue might be and how I can fix it would be very helpful and appreciated.
Thanks so much everyone.
ivin74
05 NBS Nali
Htown, Texas
Have you checked the heater core for leaks? if you smell coolant inside the cab that your problem, but if you don't use coolant on your radiator you would not smell anything.
J
jyi786
Thanks for the suggestion.
It's definitely, 100% not coolant. It's straight up water (rain water, salt water from the roads).
J
jyi786
Please look at the attached video
Yes, I did see that online!
Mine is a 2012, but the video is for the older gen. Do you think this would apply to my 2012 as well?
J
jyi786
I just inspected everything I possibly could. I can't find anything leaking.
It's snowing out, and I had the truck on, so the water beaded up on the hood and the windshield, giving me a perfect opportunity to test with "free" water. I have the truck on an incline, so when I opened the hood, the beads collected and torrents of water splashed down and ran into the cowl area.
I checked the cowl access flaps, they are completely free from debris, and I watched as the water drained. I also opened the driver side kickpanel and inspected while the water gushed into the cowl; no sign of any water leaking into the interior. I pulled up the plastic cover for the hood hinge and checked that area; no sign of where water could be leaking. To be on the safe side, I also checked the grommet which contains all the harness wires going to the driver door. It's tight and sealed.
I attempted to bridge the little gap that's above the driver's door. That didn't work out too well (messy) but I did the job, I think.
I pulled back the carpet and inspected all the areas. No sign of water anywhere from the grommets, except water seeping from the spongy firewall. This might be leftover from what I did on the weekend trying to fix it.
I fear that this may be a sunroof line leak or most likely a windshield leak. Reason why I think it's the latter is that if it were a sunroof line leak, the headliner would get discolored from water.
02Lightning
I am having the same problem but not as bad. My pad at the firewall is dry, just getting water on the floor. I was thinking of taking the A-pillar cover off and spraying the vehicle down with water and watching that area.
bryank97
Has your truck ever had the windshield replaced? Look for the GM logo on the passenger side. I had the same issue on the passenger side floorboard, pulled everything out and i pulled the headliner down, you could see daylight through the 1/16th inch gap probably 2 inches long they didn't seal very well.
Also the headliner has a hard coating on the back side, so if water gets on the headliner from the roof, it may not show through.
J
jyi786
You checkbthe shark fin up top on roof? Gaskets split and water leaks in there... especially on the back side..
I have not yet checked the shark fin. I will check that this weekend.
I'm getting water from the firewall as well. It's a constant leak.
My windshield has never been replaced. It's the original GM windshield. It has the GM logo and says AS-1 on it as well.
I was wondering that about the headliner. Every single post and video I've seen say that it eventually got stained. I only saw one video on YouTube where the guy said that it didn't show.
bryank97
Im sure the headliner could get stained eventually, but that hard coating protects it very well. Id check that shark fin next. Just keep poking around, you'll find it eventually. Also suggestion is the boots in the door jam, that contain the wiring. Check those
J
jyi786
Ok, I'll be sure to keep that in mind.
I've already checked all the boots and rubber grommets in the door jamb and at the bottom, none of them are leaking. Definitely originating from up above, since the driver side kickpanel (that opens the dash up on the left side) is where the water is visible, by the fuse box.
02Lightning
I bought this car new and the windshield has been replaced. I chased this leak a couple years ago and it was the windshield not sealed properly. I had that removed and resealed. Now the leak is back, and the windshield is suspect again for me at least.
J
jyi786
Where did you get the windshield repaired? I'm maybe interested in getting a new windshield, but I do NOT want to use 3rd party OEM stuff (like Safelite).
How do we get our windshields replaced with OEM factory stuff? Only the dealer can do it?
02Lightning
Glass America did mine, I talked to my dealer and they would of had an outside glass place come in and would not be OEM. Are you worried about quality of the glass? Maybe your dealer is different.
J
jyi786
Yes, I would be worried about quality. The OEM glass in my opinion is always of a higher standard and is much stronger than replica/equivalent.
02Lightning
I'm sure it is, I would say OEM has to pass standards aftermarket does not.
Ob1hybrid
Check the door for stored water. I had a similar situation where my doors were filling with water because of clogged drain holes in the bottom of the door. That can easily drain out slowly to the interior over time. I have a video of it draining out, easily a couple gallons.
J
jyi786
It's definitely not the door. The leaking is happening at a much greater height than the door drains. It's right where the driver side kick panel is on the dashboard.
At any rate, I sealed up the sharkfin and the roof rack mounting holes. It's supposed to rain the next few days. I'm really hoping it's not the windshield seal.
1948Buickroadie
