Misfire cylinder #4
YukonCO
I am new to the Kon and Hoe forum and have already gotten some great information. However, I have a problem with my 2000 Yukon (5.3) that I have not figured out. I get a Service engine light only when it idles longer than three minutes. After about 5 minutes it flashes. Stops flashing as soon as I drive it. I get the P0304 error (misfire #4). If i clear it and put a lever on the throttle to keep the idle at 1000 rpm - no error. Here is what I have done so far - changed plugs and wires - changed #4 coil - and changed the inline fuel filter and added B44 injector cleaner. What next before I take to a mechanic? Also, it fires immediately in the morning, but after driven and then shut off - it has to turn over for over 10 seconds before firing up again. Makes no sense to me.
BOSS
The People's A D M I N
Dallas
You're not getting a multiple cylinder misfire ??
B
92__silverado
Not to thread jack but when i start my hoe after sitting all night I get the flashing engine light also. I am hoping it is a plug/wire issue so i will be replacing those this week. If i shut it off and restart not issue.
2003 5.3 with 97k on the clock. Really hoping that its not the intake gasket.
SSmurdered
i know u see me
Pittsburgh, PA
i had a misfire on mine a while back. did plugs and wires and coil and didnt fix it. of course the last thing i tried was the fuel injector. no problems since
92__silverado
Did you clean the Fuel injectors or just replace it. I did a seafoam treatment in the gastank and of course that is when the problem started. But that is when it started getting really cold here too. Hard to tell. Hoping i just fouled the plugs but its odd that it goes away when i restart.
SSmurdered
i know u see me
Pittsburgh, PA
my CEL was on all the time and it was when it started to run ****** that i replaced the injector. i didnt try cleaning it first
04Hoe
Bad Fuel Injector, had the exact problem on my old Impala.
Y
YukonCO
I have gotten a Random/multiple misfire - but only once - the rest have been misfir cylinder #4
Max
Mile High
Denver
What brand of wire? Did the issue occur prior to the installation of the new wires or after?
BOSS
Dallas
Clear your codes, reseat the #4 injector harness. If you did all that as you said above, and are getting multiple misfire it could be clogged cats.
B
badtothe bone
western pennsylvania
The technical service bulletin tells you to change all 8 injectors with the new revised style injectors and not to try to replace just one.
If you have a problem with one, chances are the other ones are not far behind.
It is not that the injector is not squirting, it is that it is not squirting the right way, ( it's what you would call a leaky injector ) sometimes they actually dribble out the fuel and it is like trying to dump gasoline down a carburetor, you can get it to run good enough to keep it running, but you wouldn't want to drive it any distance that way.
Once a vehicle starts to move down the road and desires more fuel, it doesn't matter how it gets into the cylinders, it will pretty much burn anything you give it.
Sea foam is not a cure all for engine woe's.
In the long run the person who replaced the spark plugs, wires and coil would have been better off to have just took it to a mechanic the first time and not had to pay all the extra money - just to find out that it was not the problem.
A 02' Avalanche I had, we ran Kerosene in it lot's of times and all sorts of stuff, but never fuel injector cleaners and even after 150,000 miles, it still had the original injectors and never had a problem with the injectors.
Sometimes it will cause more problems then it will solve.
03_Denali
Gulf Breeze, FL
It sounds like a bad injector to me. Usually when a cat goes bad, an entire bank, or both, will show misfire. Change the injector and see where you are, they are easy enough to change.
92__silverado
I am going to be replacing my plugs and wires soon then getting the code cleared to see if it comes back. I am hoping it is not the injectors. I think when i looked them up they were somewhere around 80 dollars a piece. That could get expensive fast.
rigo_jones
going against
DENVER mexico
i had this and after i changed the spark-plugs 2 were broken. who ever put them in broke two and left them. to day it was 0* cold and i started the engine and it turned off after 2 seconds, i turned it on and it kept running but with rough idle but no check engine light. might be injectors ill just wait for my 6.0 swap rather than spending like $500 on injectors pus i got the flex fuel thing so might even be more expensive. btw i sea foamed this ***** already...
92__silverado
The injectors are 92.00 front Autozone and $74.28 from Gm parts direct. Damn. I do not want to go that route.
BOSS
Dallas
Yup. He's getting multiple misfires...like I said, older truck and it might be the bank2 cat or upstream o2.
How did the #4 plug look compared to the others?
Might also want to do a fuel pressure test
B
Y
YukonCO
All good info - may be more in depth than my mechanical skills. I may have to take to a mechanic and see if he can isolate it for me and determine what I am looking at for costs - Just trying to eliminate some of the easier/cheaper finds prior to going to a mechanic. May look at how difficult it is to change an injector!
varminpoolteam
