My Resto-Mod Odyssey - '08 Tahoe LT3
ernman
One of the first changes I made after buying my 2008 LT3 with 126k miles was replacing all four (4) shocks with KYB Gas-A-Just units. Had a great result on a prior heavy full-size vehicle (2004 Crown Victoria LX Sport) with them and figured I'd go this route again.
Great results with the Tahoe: good control combined with comfortable compliance.
Here's links to Amazon listings for front struts and rear shocks:
https://www.amazon.com/KYB-555054-Gas-a-Just-Gas-Shock/dp/B003WE22EI/ref=sr_1_9?s=automotive&ie=UTF8&qid=1492297129&vehicle=2008-47-499-430--9-6-8-8149--1-1-145-104-1-0&sr=1-9&ymm=2008:chevrolet:tahoe
https://www.amazon.com/KYB-551121-G...rd_wg=DXMVJ&psc=1&refRID=321JXMAT3QEKG81Q7Y5N
Did you do the work yourself? If so was it difficult.
08HoeCD
08HoeCD
I could have done it myself but did not. Had a local shop do it. Not difficult with the right tools/equipment.
NGAneer
NWGA
Just make sure you're prepared for the front struts if you have to swap and components over to your new struts. I needed a wire brush, punch, 4 lb hammer, a cinder block (which was left in pieces), a 24" piece pf pipe, PB blaster and a torch to get the spring seats off my old struts to put them on my 5100s (they don't come with seats).
08HoeCD
08HoeCD
Weird, but I'd been noticing some droning lately with the Airaid M.I.T. Removed it a few days ago and reinstalled the factory intake assembly.
I'll forfeit the extra 2hp with the Airaid for the cleaner, quieter ride with factory intake. lol
You just need some longtubes and you'll never notice the intake again.:evil27:
08HoeCD
08HoeCD
Just noticed that my relatively new rear rotor hats are rusty AF. lol They have improved my pedal feel and they are smooth in action, but, yeah, they were cheap, so I'm not surprised that they lack zinc coating or paint.
Now I'm trying to decide whether to allow my OCD to get the better of me. Does anyone but TYF members notice rusty rotor hats?
Maybe I'll pull the wheels off and paint them sometime. Or not.
HiHoeSilver
Away!
Chicago
EVERYBODY is looking at them at EVERY red light. You better get on it quick.
08HoeCD
08HoeCD
Lol!! Yeah, and "everybody" means just me and my OCD...!
Get a load of this:
Fosscore
Get a load of this:
Horrendous!! I cannot believe the other drivers let you drive around like that?
Last time I couldn’t be bothered to pull the wheels and did a little hand painted artist work through the spokes on both the calipers and rotors.
Was some nice time sitting on the ground contemplating other parts of the suspension that could use a bit of touch up too. Lol
08HoeCD
08HoeCD
Haha. Yeah, the stuff I focus on sometimes......I just don't know what's going on in my head.
Hmmmmmm........painting through the spokes. Pretty roomy......hmmmmmm
Fosscore
I just masked it off with some paper and tape, sat down and did a little brush work. Used some of the Rust O Leum paint from HD in the tiny can. Gloss black for the rotors and aluminum for the calipers.
Steady hand and for the small bits those multi packs of artist brushes come in handy.
Like this.
Don’t mind the surface rust on the rotors. Salt air from the beach and she hasn’t had much road duty lately. Will be rectified soon...
08HoeCD
08HoeCD
Looks great, and especially the caliper.
Hmmmm.......gloss black. Why not aluminum for the rotor hats?
Oh hell it only takes a couple minutes to pull a wheel in order to get clear access. Come on man.....you're Killin me!
Like this.
Does that paint hold up to the heat? Those rotors and calipers can get really hot.
Fosscore
Wanted some contrast between the wheel, caliper and rotor.
When I redid the pads and rotors with Powerstop (was not aware of the NNBS upgrade at the time) I did originally spray them with silver caliper paint.
Thought about maybe a darker grey for the calipers just for something different, but standing back from afar the calipers in that aluminum/silver seems to stick out pretty good, especially with the large area between the spokes.
Calipers seem to stand up pretty well. Usual wear and tear/salt air takes a toll, but then again I don’t daily it so the mileage stays low on average comparatively.
The rotor hats stay about the same as above with just the skinny part on top tends to disappear after a while whether it was the high temp spray paint I used at the brake change or that Rust O Leum.
They still look better than the other vehicles at the stop light!
08HoeCD
08HoeCD
Well, I just failed state safety inspection due to my LEDs in place of halogen bulbs: low-beam, DRLs, fog lights, reverse lights, tag lights. I have 15 days to correct them by installing factory-style (halogen) bulbs.
Guys doing the inspection stated that Virginia requires that bulbs have to be of the style installed originally on the vehicle or, if changed, that the carton containing the new bulbs states "DOT-approved."
I'll see what LED bulb cartons I still have. If they state anything about being DOT-approved, I'll bring the cartons in rather than converting back to halogen. Otherwise, I'll switch back to halogen, then switch them back again after the inspection. :rolleyes:
This is a drag but not the end of the world. I'm not big on doing the switcheroo back and forth but life will go on.
08HoeCD
08HoeCD
If I had any idea that these mild mods would cause the truck to fail inspection, I'm not sure I'd even install them to begin with. Kind of surprised about it. I've done mods to lots of cars over the years and never had any issue.
I guess it pays to do advance research to get an understanding of what mods cause inspection failures.
Despite this, I'm glad that we have annual safety inspections here in my state. It's very heavily traffic-clogged around here, so without inspections there would probably be lots of hoopties breaking down or causing more traffic issues than we already have.
veteran111
