Mine didn't have any screws. When I put in my nnbs shifter I added matching screws. Little precaution to slow down thieves with all the GM truck theft going on around here. Maybe it'll work, maybe not:shrug:
Mine def doesn't have the torx screws either. Neither did the Denali that my buddy parted out. Maybe they'e just on the Escalade?
95escahoe
Not sure my NBS Silverado had them they go in the circled areas here the upper one is a pain to get at, I gotta replace the shifter boot on the Esky so I’ll find out
I guess this falls under some do, some don't, depending on where it was built, I guess.
dantheman
Houston
What was it doing and which one did you go with?
it was whining under braking and steering inputs. did it for a couple thousand miles and i finally said enough is enough. it wasnt super loud but was on its way out for sure. pump shaft had some play in it once i got it off.
i got an ac delco replacement off amazon.
steering and braking both feel good now and its quiet!
Bombsquad85
Northern VA
Yep, pops out like most interior pieces do in our trucks. Pull straight across towards the drivers door (left)
Yea I got it. My lock cylinder is jacked up so I have to use a pick along with my key to start the truck haha
On a positive note my clear Sig so light housings came in and my switchbacks look awesome and match the HIDs perfectly
Bombsquad85
Northern VA
I'm thinking black mesh wpuld look pretty good maybe redo the emblem so that there is a chrome outline
95escahoe
Scored some NOS rear mud flaps for the Escalade off EBay
95escahoe
Do they make mudflaps that got the denali?
Go onto gmpartsdirect.com. and put in your vin and look under accessories, they have ones that say GMC and ones without the lettering there slightly different and don’t look to be painted, I found the part number there and searched it on EBay and found these
ASG-MikeS
