FYI - High Output Alternator
boomboom baker
Tennessee
Jimmy629
The one I have is a 1000 CA, 850CCA, group 34/78 dual terminal. Just received my terminal crimper (up to 4/0), going to swap the basttery out tomorrow for a new one, and go with dual batteries.
What battery is this?
BigDaddy13440
BigDaddy13440
Rome, NY
It's from Autopart International, one of the suppliers for Advance Auto. One of my best friends was the store manager at one locally, and I've done a lot of work for them doing repairs around their warehouse. I get the employee discounted rate for anything I need. Instead of $145 at Advance, I got it for $80. Getting a second one as soon as the temps here get up above freezing, was -20* this morning, not supposed to be above 15* all this week, and into next. I don't have an enclosed garage to work in, and I don't feel like losing my fingers (I've already had frostbite).
And my bad, it is only 800CCA, not 850. Still 1000CA.
Jimmy629
So is it like a no name?
David Smith
Savannah, GA
I am trying to upload a video of my voltage meter, but it will not let me.
Keeps saying "The uploaded file does not have an allowed extension."
What do I need to do?
BigDaddy13440
BigDaddy13440
Rome, NY
Update: the replacement ** alternator and new battery are working great. Can run my amp at full tilt, voltage barely dips at all, and when it does, I'm still over 14.0 volts (charging at 14.8-15.0 from idle to 2000rpm).
Second battery will most likely be needed when I upgrade my amp, going from the 1000 watts RMS (?) to a 2200 watts RMS (certified). Only running a single 1/0 run back to my distribution block (and 4ga to the amp), will upgrade and run a dual 1/0 run to a fused block, and dual 1/0 to the new amp (with dual 1/0 to single 1/0 adapters for power and ground).
Joao GANDAREZ
Nj
I got one of these off ebay for $115 came with sticker that says 253 amps. had it for a few days. Need to do big 3 then see how it works. need to swap in the electric fans aswell. Then comes music maybe
Drewphil
