2018 Yukon Denali - Door Alignment Off?
Ryan6769
** photos posted further down page 1 **
I noticed that the door alignment is off a little bit on my '18 Yukon Denali. And it's only like this on the driver side -- passenger side is perfect.
When I shut the door, the gap between the door and the rear door isn't flush. It almost looks like the driver door wasn't shut all the way, but it is.
Has anyone had an issue with this? I've had the truck 3 weeks and just now noticed it. A vehicle this expensive should not have an issue like this.
For example (this is NOT my vehicle):
The area highlighted in green is fine, no problem. The area highlighted in red is where the problem is — it’s not flush. The worst part is the very bottom of the red area.
I wonder if GM would warranty this. It can't be within 'normal' tolerance.
sickk23
New Mexico
“A vehicle this expensive” sorry man but no matter the price, it’s possible. My 2014 Lexus had a leaky sunroof and my 2016 BMW had many issues not worth mentioning.
I don’t have this issue, but I’ve had that part of a rear door sticking out on an Explorer that we use to have. I’m sure it could be fixed under warranty. “Fixed”, that is, if you can land a competent tech that’s as big of a perfectionist as you.
R
Ryan6769
Alright I just went out and took some photos.
Driver side -- see the issue? It isn't flush at the bottom:
Passenger side (flush):
sickk23
New Mexico
Ehhh it might just the pic, but I’m not sure you’ll find anyone working for GM that can get that door anymore flush.
R
Ryan6769
^^ If I run my hand across the lower panels on driver side it's not smooth -- the door is sticking out. It's completely smooth/flush on the passenger side.
R
Ryan6769
^ I will be scheduling an appointment to have them address it.
I'm wondering if anyone else has ever had this problem before and what their experience was with GM ...
15YUKON
I wouldn’t be that concerned my door isnt perfect. As soon as you have them start messing with the hinges stuff is going to start getting funky.... if it were me I’d leave it. Hinges are on and that’s how the door wants to sit. My Expedition always had a misalignment on the door too never bothered me or effected operation. Pretty much any maker has the doors a hair off on vehicles if you look close enough.
dbbd1
My .02?
I think that could be adjusted to fit flush and I would have them do it.
GTNator
Senior Member
I completely agree with the above. I do see from the picture that it’s off a bit, but it’s really, really small. And as long as it doesn’t affect performance (air/road noise, water leaks) I would just leave it. If the dealer starts taking the door off and messing with the alignment, it could get worse and might actually start affecting performance of the door.
I’m a perfectionist too and these things bother me as well. But in this case I would ignore it and start enjoying that beautiful ride!
cardude2000
It’s a 40k American truck (dressed up with a bunch of baubles and bolt ons). Stuff like that comes with the territory.
Oh and my Denali has a similar issue. I’m a crazy perfectionist but there’s no chance I’m having the dealer fuss with it. The minute they do I know I’ll have another squeak to live with.
Dave Legacy
One of my doors doesn’t align perfectly either. I didn’t notice until the first time I washed it and ran a hand over it. There’s a few other things around the truck that are similar that I’ve decided to not make a big deal out of - Like the other perfectionists who chimed in here that don’t feel like making nothing into something.
The truck isn’t perfect and I can live with that.
jason952
I think they may have done this on purpose for decreased wind noise and buffeting
mike6681
I have the same thing on my 2018 Suburban, its covered but I didn't do anything cause when they start pulling to line it up it can make the rest worse, so I chose not to. Check your paint well, I have blemishes on the roof, back hatch, and hood, runs on the door edges, probably the worst factory paint I have seen on a chevy yet. Chevy body shop says, hatch needs to be repainted, whole roof and hood. I don't want to bust the factory clear, still deciding if i can live with it
gonatee
Yeah my door lines are off also and as months go by you're going to start getting more and more rattles and failures. I've had mine for five months and every month Im less impressed. Thought enough time had passed since the bail out but apparently not. GM is obviously still cutting costs and corners.. not only on their vehicles but in their service/tech department. Like other members are saying don't let them touch it! You'll end up with more problems, frustrations, wasted time and money. Sad this is just expected and has become the norm on a $70,000 american made vehicle. I planned on selling this thing around 50k miles now I'm thinking more like 30k just to avoid the frustration. There obviously was a reason GM went bankrupt and this is what we should expect when we allow a failed company to continue doing business.
Obravada
I have a 2015 Tahoe with the same problem on the driver side door (only on the lower part of the door).
PG01
Up here to the right
Guys, open the window all the way and door all the way. Have someone pull on the door from the window frame down as if they are trying to open it and you put your hands underneath from a squatting position as if you were getting out and dropped something and pull as if you were trying to close the door but more of an upward motion. Do not jam on it just gently pull up, I can guarantee you will get that bottom corner to pull in a little more. DO NOT PULL LIKE YOU ARE TRYING TO KILL SOMETHING, just a gentle tug.
cfoote
Snellville, Georgia
I have the same exact issue on my 2016 Denali in the same spot. I believe the door itself is aligned properly but there is a defect on the outer shell of the door. I haven’t said anything because I don’t want them messing with the hinges
Kcrowe79
