I've got the dreaded vibration/boom
DennisT
My 2016 Denali has about 21000 miles on it and it's been great up until today. I started out like n the road today and when I got up to 60 I could feel and hear a rhythmic booming sound. Rhythmic in that it was on for a second and then off for a second. That continued for a while. At first I thought it was the road. I changed roads and speeds. It kept coming back. It seemed to stop once I dropped below about 45 mph. It sounds like a kid next to you with his bass booming. I dread dealing with this.
DennisT
DennisT
After further driving today the vibration/shudder was at speeds as low as 40 mph and the shudder frequency seemed to vary with speed. I think I felt the transmission slip a couple of time on the 2/3 and 3/4 shifts. Could it be a torque converter or tranny issue? I've got an appointment to take it to the dealer on Thursday.
acainindy
Knoxville TN
Have your dealer check the ring and pinion for excessive wear and a rounding of the teeth. Road force balance the tires, and check the roof cross members! After my dealer replaced the ring and pinion, all the pressure went away!
rjhoskins
My '15 Denali XL is at the dealership right now.....new torque converter getting installed. Have had a progressive problem just like you described for the past couple thousand miles. Took it in yesterday and sure enough it's the tq converter. Currently 23k miles. Good luck.
DennisT
DennisT
When your problem started was it intermittent? Did your problem get progressively worse? I was scheduled to take mine into the dealer today but I cancelled the appt because the problem has presented itself the past two days. I hate taking it in and then they can't find the problem.
rjhoskins
Yes, my problem started off as a 'now and again' problem that got progressively worse over the past 5k miles. It was so progressive that I wasn't sure if it was getting worse or if it was my imagination. Then my brother borrowed my Yukon to move some furniture (shocker), and returned it with the quote, "What the hell is wrong with your truck."
Then, over July 4th my family all hopped in for a trip to the mountains--my 16 year old daughter in the back seat stated, "Why does it keep vibrating like that", then my wife replied, "I was wondering the same thing!" So, off to the shop yesterday....currently driving a loaner Canyon which isn't too bad I guess. :)
acainindy
Knoxville TN
Zeus2015
Did replacing the torque converter fix the issue? I get my '15 Denali back after the fix tomorrow.
rjhoskins
Yes, my Yukon runs like day one again. Thanks and good luck to you!
DennisT
DennisT
Thought I would give everyone an update. I had an appointment to take my Denali in for the vibration but I cancelled it. The next day there was no vibration and it hasn't re-occured yet. I felt it would do no good to have them chase something that wasn't happening at the time. I wish it would re-occur so I can get it fixed .
DennisT
DennisT
Here's an update to this thread. My Denali vibration finally occurred again to the point I could take it in for warranty work with 28,000 miles on it. It was very bad today when I rode with the tech. He immediately diagnosed it as a torque converter problem. Left it there to be replaced.
acainindy
Knoxville TN
Have your dealer check the ring and pinion for excessive wear and a rounding of the teeth. Road forcebalance the tires, and check the roof cross members! After my dealer replaced the ring and pinion, all the pressure went away!
Tahoe14
Central Fl
acainindy, how many miles did you have on yours when they discovered the issue with the ring and pinion.
acainindy
Knoxville TN
It’s first started around 8000 miles... They started diagnosing with the roof rail bulletin, then road force balance of the tires, then replaced the tires with Michelin’s. Then checked the drive shaft, replaced the shocks and finally the Ring and Pinion around 12,000-15,000 miles.
Tahoe14
Central Fl
Thank you I have booming in my 2017 Tahoe Premier at 5,000 miles and just trying to figure out what I have to look forward to and what approach to take to get it resolved.
GTNator
Senior Member
I’m curious as to whether this will work. How long until you get your vehicle back?
DennisT
DennisT
They didn't say. But I would say it will take a few days with the holiday thrown in. I'm in no rush. I'm putting miles on their Acadia.
GoCardz
Same here! I pick mine up tomorrow.
GTNator
Senior Member
Did all the “fixes” work?
Candielaine
