W8TVI
Traverse City, MI
Looking for any thoughts or advice.
2nd row dome light blue LED stays slightly illuminated after the map lights and cargo area dome lights go out, either by timing out or locking the doors by the remote.
I sat in the 2nd row and tried different combinations, yet it stays lit.
I did not pull that bulb yet and try another one.
Here are a couple of pics.
Thoughts?
All interior lights on.
After all other interior lights are out.
I'm pretty sure you just need to make sure you are using canbus LEDs. Canbus LEDs have loading resistors in them (I think) that allows the truck to tell there is a good bulb in there.
BigDaddy13440
Rome, NY
BORING. I want to be a general contractor. I hate offices. A jacked up work truck will be the only office I'll go in
I'll have to take exception to that!
I AM a General Contractor, and subcontract for Lowe's doing installs for three stores. Mostly do door installations, but also countertops, tile, bathroom fixtures, and full kitchen renovations.
My XL IS my work truck.
BigDaddy13440
Rome, NY
Just picked my XL up from Goodyear, my front brakes were toast.... as in metal to metal. Mechanic hit the old rotors with a hammer and they shattered.
Luckily, as I'd mentioned elsewhere, I found a set of EBC rotors and Greenstuff pads on Craigslist locally. He said he'd bought them from Jegs for his truck, and wound up trading it in before he put them on. Had them listed at $200, they are over $400 if buying from Jegs - I offered $150 and he quickly agreed.
CamReynolds
still a good work truck. you mind if i pm you about the job?
inmypassatlife
Bilstein said they were for stock height trucks.
But I am sure there is a different model available for lowered. I will call tomorrow and find out
4600's with shock extenders? I'm asking because I'm on the market as well. I may need to perform the free travel mod as well
#1taho
5150TAHO
niagara falls ont
That I am not sure of. They didn’t mention it either time I talked to them. The 800 # doesn’t work on there web site. But here is a number that does work. They are easy to talk too and very knowledgeable
1-858-386-5900
Hodmjstone
