Rubber coil spring insulator
temper
So I'm doing the nivomat replacement with Bilstein 5100's, Moog Z71 coil springs, and WheelsNParts torsion key/2" coil spring spacer kit this weekend. I also bought two Moog coil spring insulators before I decided I was going to do the spacers.
Have any of you used these with your coil spring swaps, whether you're using spacers or not?
temper
temper
Yes both bottom and top of the spring then let it sit on the spacer...
Yeah, I discovered that there were some already in place on/under the stock shocks, and in rather good shape for having 220,000 miles on them assuming the previous owners never replaced them. I ended up replacing the top one, just because I had two new ones. I tried to get one to fit in between the 2" spacer and the coil spring, but it wouldn't fit over the spacer.
SlimJim
So i have a question about the moog 81069 springs. Do they provide any lift. I an 04LT model that i want to put 5100s on. It has a supreme suspension 2" front 1.5" rear spacer kit. Im wondering if i go ahead and take out the rear spacer and replace them with moog 81069 springs will i still be level. I heard that the springs provide anywhere from 1-2 inches. They do need changed, but i dont want to have any rake i just wanna be leveled. Also how is the ride quality compared to stock springs.
Off Road Pedia
