2016 rough idle
RyansTahoe
Jus tfound this thread and have the exact same issue with my brand new 2017 Tahoe Premier. Took to dealer and they said it was normal...so here I am trying to find a solution myself.
Fred_e81 - any updates on your end?
BobMc
RyansTahoe--
After the motor is warmed up---
At a full stop--
Just add about 100 to 200 RPM and let me know if the shaking stops.
thanks!
Bob
RyansTahoe
RyansTahoe--
At a full stop--
thanks!
Bob
Yes it will stop vibrating if I put in neutral or leave in gear and give it some gas.
BobMc
I am convinced that the low RPM is causing the motor to vibrate because of ????.
Cylinder deactivation??
Fuel pump problems? This area might be discarded as an individual at the start of this conversation did have a pump replaced.
The dreaded "fuel pump ticking" has finally killed something someplace?
Who knows???
Now if the dealers would only touch up the idle I am also convinced that the problem would be solved.
Any GM types listening?
be safe.
Bob
Mark L
This is how GM addressed my 2016 Suburban Rough Idle
Dear Mark
Per your request, here is a summary of the final resolution for your 2016 Chevrolet Suburban, case number 8-3067935080.
The vehicle is operating as design this is a normal characteristic. With the vehicles with the VLOM engine . I do apologize that this is normal there is no fix .
Chevrolet does review each customer’s concern on an individual basis. All the facts in your situation were carefully considered, and we have determined that this decision is appropriate given the details of your case.
Regards,
Mary
Chevrolet Customer Assistance
Phone Number: 1-866-790-5700
Extension Number: 5921467
BobMc
Mark--
Your post is EXACTLY what the assistant service manager at my dealership told me.
He also told me--
Get an aftermarket tune to raise the idle RPM 100 or 200 RPM. We are unable to do it because of emission regulations.
Wow.
Thanks GM.
I bought my first new GM product in 1968. (Yes--I'm OLD.)
My truck has been at the dealer's for over 60 days for one problem or another in two years of ownership.
This 2015 Tahoe is my last GM. Period.
GM--Can you say "Buy back." because this guy has been a long time GM owner?
Be safe.
Bob
Mark L
Dear Mark
Regards,
Mary
Mark--
He also told me--
Wow.
Thanks GM.
Be safe.
Bob
Bob,
I'm sure there is a fix, GM just doesn't want to "mess" with it. I'm like you, have driven Chevys for many years. Can't believe we spend that much money on a vehicle to have it miss and shake at the stop lights. The lady I dealt with had no clue as to the mechanical workings of their product, all she is is a glorified note taker for GM. If you read her statement, she can't even write complete legible sentences. I'm not done yet. I'm looking into legal action and a complaint with the NTSA.
BobMc
Mark--
I'm await your updates.
Fight the good fight.
Be safe.
Bob
Tally2
I was experiencing the same rough idle in my 16 Tahoe. I took it in and both motor mounts replaced and still rough idle just not as bad.
Now, this is how they fixed it, the tech loosing both engine mounts and tranny mount a bit drove it around the block and then came back and re-torque to factory specs. Then installed their vibration sensor to read the car in idle on driver side floor board. Now, my Tahoe idles like butter. You can barely even feel it running now.
Geri Martin
Has anyone been able to get to a satisfactory resolution on this? I've had my 2016 Tahoe in 4 times now for this issue. They kept if for a week on the third try and told me that it still wasn't fixed. Magically on the 4th repair attempt, when the lemon law kicks in for my state, I'm told that its 'within the range of normality'. From what I've seen on here, I'm not the only person who doesn't accept this as normal.
SSMC
I had a 2015 Tahoe that was doing this exact same thing, it was so bad the dealership bought it back. I then purchased a 2016 Tahoe that is having the rough idle issue!! GM said replace the motor mounts, I'm 1,100 miles out of warranty so I have to pay out of my pocket for the motor mounts. Is this a sure fix? The dealership says probably not. I have been going back and forth with GM about this and they refuse to be of any assistance to me. Possible Lemon Law case here, maybe even class action lawsuit. GM is aware of this issue and can't get their acts together to fix the problem.
Miami-Dade
Moderator Supporting Member
I get the rough idle on my 16 Hoe but not everyday..I generally get it when I am in gridlock..With that said every vehicle I have owned has had rough idle here and there..Have not been to the dealer yet..At least not yet anyway.
Tahoe14
Central Fl
Geri, SSMC I went through this with my 2015 with different issues and ended up doing a successful Lemon Law as have many others. What I learned was GM is not your friend and they don't care about you as you are just a number. I even wrote the CEO of the Chevrolet Division after multiple GM purchases and did not even warrant the decency of a return response. Also I would hire a Lemon Law attorney which in most states you do not pay for as there fee is part of the Lemon Law settlement. Just do a Google search in your area for Lemon Law attorney. Do not let them wear you down or try to discourage you or intimidate you as they will. Good luck.
lynxnova
New Jersey
I’ve been dealing with the dealership for about a month now with the rough idle issue... they replaced 2 motor mounts and it still has the rough idle, especially at gridlock traffic.... I’ve had my truck for a little over a year and this rough idle situation started about 2 months ago... it’s definitely annoying... it’s now back at the dealership, the service manager is telling me that it’s nothing else they can do but I refuse to take my truck back with that problem. I have no clue what to do next but maybe start sending emails to corporate in Detroit .
vishnu619
I had this issues on my 2015 and the dealership said there was nothing they could do. I purchased a catch can and cleaned the intake, throttle body etc. and the issue went away. Seems to be the oil being put back through the system clogs it up and causes the rough idle. May not work for everyone but it did me. The dealership had also offered their service to clean in the intake system for $200 bucks, better investment to get a catch can imo
Geri Martin
Thank you everyone for your input! Tahoe14, I did not realize that I didn't have to pay the Lemon Law lawyer up front, so I will start making calls on Monday!
This is so frustrating. I put a lot down to keep a low payment since I have two kids in college and my youngest is autistic. The dealership tried to bring me in and show me how 'underwater' I was in my current lease and that to get into something comparable I would have to go from a $300/month to a $900/month payment!
SSMC, I am with you on the Class Action part. I'm submitting a case on classaction.com.
Thanks everyone! I feel much better now!
Geri Martin
I've had motor mounts and transmission mounts replaced, and it's still there.
SSMC
It's really frustrating that is what it's come down to. I have been in touch with a lawyer and will keep you posted. :)
BadDaddy2003
