Intermittent clacking noise
Rexxrally
Edmonton AB Canada
2005 Yukon 5.3 engine.
When cold, engine runs and sounds just fine.
Once it's warmed up, and left to idle for 5 minutes or so, it starts making a clacking noise. It's quite noticeable when the Yukon is beside a building (like in a drive-thru line). If I rev it up, the clacking noise increases with the speed of the engine.
If I drive it after that, the clacking noise will go away after a few minutes.
The whole time, even while clacking, the engine runs perfectly (full power, no hesitation, no Check Engine Light, no codes thrown).
Has anybody had this before, can give me an idea of what it could be?
Thanks!
DenaliJJ
What’s the oil pressure at when this noise comes and goes?
What's normal? 40 at idle and 50-60 at higher rpm's is considered normal for the 2000-2006's. It's different for the 2007-2014's which usually sit at 20 idle. So if you're seeing 40 at idle then it is normal for your year.
R
Rexxrally
Edmonton AB Canada
Well, being Canadian, our gauges have a different scale. Mine shows 250 in the middle of the oil pressure gauge. While driving, the needle points just right of the 250. While idling, it points just left of the 250.
Sounds normal then; on mine 40 is in the middle, straight up. I'm thinking it sounds like you have lifter noise or piston slap but I'd be more inclined to go with lifter noise. We need to hear it- can you do a YouTube video?
R
Rexxrally
Edmonton AB Canada
Here's my video of me in the drive thru line.
SirReal63
Bertram, TX
If you haven’t done a motor flush, I would. The oil galleries in the lifters are small and can get clogged easily. It is fairly common and easily rectified. If a good flush doesn’t fix it you may be pulling heads.
I can't tell for sure, but that doesn't sound like lifters to me. Maybe try using a stethoscope or the old trick of holding a big screwdriver or something to your ear while putting the other end on various areas of the engine to pinpoint where it's coming from. Kind of sounds like a pulley.
06Escalade
The video sounds more rod knock than lifter. Open the hood and verify every single exhaust header manifold bolt is intact. I had one that rusted and fell off, sounded similar
He can check those for sure but FYI, I had 4 broken exhaust manifold bolts and mine never had an exhaust leak.
R
Rexxrally
Edmonton AB Canada
I finally found out what the noise was. In case it happens to anybody else in the future, it was a cracked exhaust manifold, allowing too much engine noise to get out. Once they replaced the manifold, the truck sounds wonderful again.
SirReal63
Bertram, TX
Good news! I have seen plenty of snapped bolts but I don't think I have never seen a cracked manifold since SBC days.
When I installed long tubes last summer, when I pulled my DS manifold off it was cracked between 2 bolt holes where one of the bolts had broken off.
SirReal63
Bertram, TX
I do not doubt it. It makes sense if broken bolts are not replaced, but I cannot remember ever seeing it.
Skiroy56
