Bombsquad85
Northern VA
Any updates to yours ? Love how you painted your grille.
It came out decent. No where near show quality. I used SprayMaxx 2k clear and it's starting to peel. Eventually if this truck last long enough I'll get a pro job
If I remember tomorrow I'll grab a picture
TheAutumnWind
The correct exhaust tip came the other day, either getting the muffler and tip put on this weekend or next week, e-fans came in, and scored another NOS Escalade intake emblem
nice! where did you find the emblem? Mine is fading... everything i can find is aftermarket.
95escahoe
On EBay there is one more on there for like $20 shipped PM me if you want the EBay link
TheAutumnWind
Thanks! I need the grille and rear hatch emblem. You said "intake" emblem? You must mean the intake manifold cover? Mine is ok. Love how your lade is coming along btw!
95escahoe
Oh damn ya it's the plastic intake cover emblem only came on the 02's you can find the rear OEM one on EBay think it was at or under $100 the front one probably the same
TheAutumnWind
Yeah 02 had the best covers. real slick.
WIsh I had time to keep mine that clean. Drove the family up tot he mountains this weekend and every square inch is covered in dust from dirt lots and gravel roads!
95escahoe
I pieced this set together found the center one on EBay and the side ones off a GM parts site and honestly I never clean it that much I'll just blow the compartment with the air hose and do the plastics quick it's still holding up from when the dealer cleaned it when I got it last year, I sent you a PM with those emblems not cheap more then I thought
TheAutumnWind
Yeah the wife would probably kill me if I dropped 300 on emblems. haha. I really appreciate it though.
95escahoe
Well got the muffler and tip installed today (don't mind the filthy truck) looks pretty good might have the tip tucked up closer to the body, could go up a tad, going to get a Corsa cat-back down the road so this isn't really permanent, sounds great need to get some clips
Countryboy07
Getting it up closer to the body would look a lot better. Glad your liking the sound of your Magnaflow!
Looks like it needs to go up and in. When I had mine done the muffler shop had the tip on an adjustable stand and he kept moving it around until I liked it, then he bent some pipe and tacked everything together just enough to pull the stand, then had me check one last time before he made it permanent. Seems like a lot but there's quite a few ways that it didn't look right and only one way that really looked great.
95escahoe
I'm thinking something along those lines, the way the factory exhaust is it doesn't really come out straight has a slight angle to it, so I'll have to have the pipe cut back and a new section welded in cause idt the factory pipe there can be modded correctly to make it look right
Yeah they cut out a section of mine and bent up a new piece. It took him a few trips back and forth from the pipe bender before he got it.
CamReynolds
When I De-badged my truck, I used braided fishing line, some Goo-Gone, and an eraser wheel on a drill. And I used them in that order. Then I polished that area with some polishing compound and some finishing polish, and the outline on the paint completely disappeared.
And the braided fishing line worked GREAT because it has some texture to it, so it's better for sawing back and forth on the foam mounting tape.
Here is a before and after picture of mine De-badged. View attachment 183722 View attachment 183723 View attachment 183724
do you still have the rear chevrolet label that you took off?
BigDaddy13440
Rome, NY
Those are the same Denali wheels I just finished painting!
You don't have any wheel spacers, do you? I've got a set of rivet-style flares going on mine, with 2 1/2" spacers on the rear, 1 1/2" on the front. Hopefully, the rears should stick out just about an inch, with the fronts flush....
95escahoe
You'll like them on your truck they look good on the NBS trucks, nope no wheel spacers they are reproduction rims but I think they are the same offset as the OEM rims
NjA4207
