Brake hose replacement
Wagnasty
I'm looking to replace/upgrade my brake hoses to stainless braided. To the ones that have done this what brand or kit are you purchasing? I found some from stop tech but it was only the front lines.
W
Wagnasty
I wish those kits would work. Mine has 6 brake hoses. Both of those listed were for 5 if I read it right.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Goodridge 14196
It's a complete set. 6 lines. The extra 2 replaces the rubber mid lines that above the rear axle.
I bought fronts and rears from stop tech, just have the fronts installed for now. No complaints. I also went with stock bigger brakes from an 07 Hoe. Thx @sumo .
mals
Western Mass
I just ordered this set of lines from Goodridge for my 2005 Yukon, and hope to complete my brake upgrades over the long Thanksgiving weekend. Did you have any issue bleeding out all the new brake lines without having to activate the ABS module or StabilaTrak system with a Tech2? I picked up a Motive Power Bleeder, so I am hoping if I force the new brake fluid through the lines without turning on the ignition or pumping the brakes I will avoid trapping air in either of those systems.
Thanks for any pointers in advance. Hopefully the full braking system overhaul will go without indecent and I can post some photos and tips of my own afterward.
Chubbs
now you guys have me wanting to get a kit of Goodrich lines.
I think you just vacuum out the old brake fluid from the back, pass side caliper and begin adding new fluid just as the old fill reaches the bottom of reservoir. Continue draining until new, clear fluid is running out. After that you do the back, driv side & then front pass, front driv. You don't necessarily have to pump the ABS module unless it was opened or replaced.
For other makes of vehicles, it is common practice to jump the relays to pulse ABS module like Tech2 or any other software does. I've never done it on 1 of these trucks but I'm sure it will work the same way. Just saying for future ref, high end software isn't required to bleed ABS. Furthermore, physically activating the ABS as in driving the vehicle, will move the air into the lines which can then be purged @ the calipers. More time consuming but same results can eventually be achieved. I have a LR with hill-decent option that makes the ABS software obsolete. Just find a steep hill to drive down, push the button and ABS pumps until it doesn't sense any more resistance.
mals
Western Mass
Gravity and fresh clean brake fluid is your friend.
I've done plenty of brake bleeding in the past, but this will be my first time on the Yukon. I was worried that since the typical Goodridge brake line kit only has 5 lines, and the set for vehicles with StabiliTrak have 6, that the extra line would be deadheaded by the StabliTrak system. I didn't want there to be a line that I couldn't bleed without the system being active.
Looking through the forums, I didn't see any specific mention of it, so I figured I'd ask someone that has done this exact upgrade to make sure there are no surprises while I am on my back under there.
Glad to hear that I am just overthinking it (as usual).
-mals
Chubbs
Oh I see. Ya, I also like to search online conversations and gather as much info possible before doing work on a make new to me. Smart guy. Most of the time your electronic braking system occurs above or outside of the master cylinder so nothing to be concerned with where you are working downstream. At least in my experience. A lot of different aftermarket suppliers of SS braided brake hose provide that extra piece for the rear end junction but still nothing to interfere with electronic systems.
sumo
rhode island
I own a snapon modis ultra. I used the brake bleed function that built into it.
Chubbs
Must be nice.
But obviously when he said 'Tech2' I'm sure that was meant to include any of your $1k-plus hardware
sumo
rhode island
I’m a mechanic so it’s more of a necessity than having it just because. You can also use a power bleeder like a manual mighty vac or air powered one.
Another option you can do is crack and bleed at the lines on the abs module
Hodmjstone
