Cruise control not working
Snacky
Hmm, what i just got must be old style then. I tried it, and lifting off the brakes just a bit made the lights go off but my foot was still engaging the brake a bit.
Does the AC delco part 25981009 mentioned above make the brake lights stay on until foot is removed from petal, or closer to it? If so, I think I'd rather have that one and don't mind spending the 15 bucks... now that I know what to do the swap only takes a few minutes.
JGman
I have a new to me 2011 Yukon XL that just went on it's first road trip. All was well for the first 3 hours with the CC, but functioned intermittently after that. I did notice that, if I just barely touch the brake pedal (I don't actually feel the pedal it's such a light touch), the cruise drops off and will not reengage. Unlike my truck that you actually have to push or move the pedal to have the cruise drop out! I'm guessing the switch is so sensitive, the bouncing of the pedal from highway bumps may be disengaging the switch!
I could put a "return spring" on the pedal and test the theory. I'll pick up a switch and give it a whirl. I'll post an update. As others have said, "Thanks to all for sharing your knowledge!"
JGman
Replaced the brake switch with a "Standard " brand from my local Independent parts house. Just returned from a trip to Mississippi, approximately 1400 mi including the riding around while down there. Cruise control worked perfectly! Never once failed to engage. Thanks to all here for your knowledge and wisdom and sharing it with the rest of us. By the way, it really is just a 10 or 15 minute job to change.
Straft
I'm in the same boat as you. I have a 2003 Yukon XL Denali I have gone through all the fuses and electrical for the cruise control I did find my 3rd brake light did not work. So have replaced it. No luck with the cruise. I would like any in put anyone has. Please
Does yours have a switch attached and above the pedals?
PeoriaBJJ
New to the site. I have recently bought a 2007 Tahoe as a secondary family truckster. No CC when I bought it. Everything else works so Im gonna but a new connector mentioned and see whats up! Cool forum! Im sure I'll be using it a lot!
fldsprinter
Gentlemen,
I have the same intermittent problem of the cruise control. I made sure there were no codes in any module on my truck using the Tech 2 scanner. Then I rushed and got a new switch and changed it in 5 minutes or less. I was very disappointed when the control didn't work :shocked:. All the people in this thread were happy because it worked with them immediately :gathering:. I don't know why it didn't work for me although I'm pretty sure there are no codes present. The part I installed is brand new. The ACD number is D1539J.
GM number is 25981009. Its picture is in the attachments. Could anyone help?
Is this part called a "brake position sensor?"
Johnniev57
YAY! Looks like an old post. I just bought a '11 Yukon XL Denali a couple months ago. I was so mad that the cruise didn't work! Luckily I found this post!!! Easy fix.... Only thing different is I have a bolt that goes into the clip.... Thanks for this post!!!
Coalhat
I was having the same issue. 2007 Yukon SLT 5.3. Intermittent functionality, really to pattern to when it would work and not work, but a major bummer on a 2000+ mile road trip. After replacing a headlight bulb the problem is gone. Is it possible that an "about to burn out" bulb could mess with the cruise control? Nothing else has been changed, but I have no more failures with the cruise.
Jayk
Hi everyone! So far, reading through all these is giving me a good idea of what needs to be done, but I thought I'd put in my situation and see if anyone has any other ideas. I have an '05 Yukon, cc worked fine up until just today that I know of, but I haven't used it in about two months since it's been winter. Today was a balmy 35 degrees, roads were good, and I use my cc a Lot. I wouldn't have thought it related until I read through other experiences here, but here's what is going on. I tried to activate cc (mine is a button on the blinker control stick), and nothing. Pressed it again and nothing. Pressed it a third time and saw the dash light for it light up dimly for about a second, and then nothing. This is where it get's into ideas I got from this forum: The other day, my right rear blinker went out, pulled over at a gas station, pulled the capsule off, checked the bulb, but it was fine, then found it was all three right tail lights weren't working. *Important detail?* Took it in to the place I go for things I can't do (winter and no garage means most things right now), and it turned out it was just the connecter for those lights pulled out because a block of ice built up on the wire, they cleaned it for me, hooked it up, and didn't even charge me for it. After it was fixed, I noticed that night that same side backing/perimeter light was out (probably from me messing around with it, no big deal. *Important detail?* So today, before noticing cc didn't work, I went to my local napa where I buy all my parts and got six new bulbs, not LEDs, just bulbs, and replaced all six tail light bulbs, figured I'd just do them all at once. It was on my way to work from there when I noticed cc didn't work. So I'm wondering if maybe that the truck is 12 years old (still runs fantastic!), and a complete fluke, and maybe the brake switch just stopped working, or if the tail light connector or new bulbs could be the culprit. Unfortunately it's supposed to freezing rain all day tomorrow, so I might not get a chance to check anything for a couple days, but I didn't throw away the old brake light bulbs yet, so I'm wondering if maybe that's the culprit. All six lights do work properly now, but I use cc constantly in good weather, and would be devistated if it was gone. Also I don't know if it could be connected in any way, but My ABS light has been on since I got the truck over a year ago, and in the fall one of my calipers seized, and since then after about 2 seconds to several minutes, I get 30 seconds of ringing and a "service brakes soon" message, but I've had it checked and it looks like it's just the sensor in the bearing hub which I'm doing once spring hits (meant to before winter, but then winter happened faster than I could get around to it). I'm sorry if this is more information, I don't usually post to things like this, I just want to get any info out that could help. Also, sorry for the massive wall of text. Thank any and all of you who are able to help me in advance, and if you need more details, please ask. I will check back and when I find a resolution, I will report back as to what it finally was.
I believe if there's any issues with your brakes OR brake lights, CC is disabled as a safety feature. I know you said you checked all 6 tail light bulbs, but did you check that the brake lights all work when someone steps on the pedal? If so, I suspect it's the ABS or service brakes soon issue.
doc_sun
Scotcher
Capital Area, NY
^^X2. Colder weather affects a corroded brake switch like a fiend. Then ANY issue with brake light malfunction will disengage the cruise control as per safety standard. So you may have a combination of both issues. You can try and "cheat" on the brake switch by climbing up under the brake pedal and spraying some Fluid Film into the switch (just for now) to see if that might isolate the issue.
Jayk
Thank you both for answering so quickly. In response to Rocket Man, I did do a full lights check after I did it, I was just an the Napa parking lot and one of their guys pressed the brakes for me so I could make sure they were getting brighter properly. In response to doc_sun, is fluid film something I can pick up at any auto parts store? I've never actually heard of it before. I've been doing mostly my own repairs for several years now, but I still don't know everything. I'm hoping it's not the and/service brakes soon message, those have been around for a while, but I wouldn't rule them out just for that reason. The other thing I wonder is if the tail light connector came undone and sat there undone for a couple days while still driving around, could it be possible that the connection is good enough to light up the brake lights, but not good enough to keep cc going? Also, small update, while I was driving home, I tried it again, and found that if I rapidly press's the set speed button, the dash light does try to flicker on, but still faintly and doesn't last, so at the very least I feel like I can rule out the cc set button. Also, doc_sun, would I just spray the fluid film directly into the switch? Just being sure before I do something to accidently cause other problems.
6point2lovelifers
