seven9st surfer
Finished up my nerf bar restoration, cleaned all the bug guts off the front end and made myself an actual signature. Props to Pete aka Sevenevez for the inspiration.
Finally got around to installing the LCA bumpstops I bought in December of last year.
Took them to the grinder to maximize contact area with the factory bumstops.
Not perfectly centered, but pretty close.
Can't say I've noticed a huge difference, but it does seem like the front end is more "connected", for lack of a better term.
I completed the cabin filter mod today! Time wisely spent retrofitting a set of those filters to the HVAC; my AC doesn't smell like a hay barn anymore!!
I haven't come across any threads on it here so either you all did this already or this generation of owners is unaware of it. Hella benefits.
I got the oil changed too. I used the AC Delco Dexos full-syn, 5w-30 & Delco filter. Now, I was losing ZERO oil on whatever fill the previous owner had put in it. I assume the cheapest DINO oil because of the $2 Pennzoil filter that was under it. I really don't want any leaks or oil consumption to arise so I will be checking it on the reg & sharing my findings for those interested. Replacing the torsion bar crossmember bushings this weekend too: my tuck has recently developed a serious "CLUNK" sound that has become ever more persistent. If my luck holds, this will do the trick and I won't have to spend any time diagnosing the ball joints and body mounts. I found a set of the mount & bushing assembly for $30 on eBay. We pressed the new bushings out of the mounts so that I can swap the bushing only instead of transplanting the entire mount as a whole. Im going to attempt the old all-thread/washers/pipe as a makeshift press while hammering down with a 1/2-inch drive impact instead of socket/ratchet. May try to document.
You might need a set of shock extender brackets.
Is that the factory shocks in front, there? That is quite a bit of lift you got there. I put in some lift keys that completely leveled my truck out and I still have the bump stops touching the CA. I don't know how as they were up about 1-inch but I played with the adjustment bolts a few times and got them back in contact again without sacrificing any of the lift.
I have to replace the bushings up in that torsion bar cross-member tomorrow so we will see if that changes anything.
My 03 doesn't have it.They stopped for the 03+ years.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Neither does mine.My 03 doesn't have it.
Highly recommend TheSeatShop.com replacement leather. I just did mine.No pictures buy I ended up buying a magnaflow exhaust off eBay (one I posted a few weeks ago) and over all not bad the tail pipe was angled a little low so I ended up weldibg a factory hanger to the tailpipe to get it a little higher. Sounds good and fixes my problem. Ibalso changed rear brakes because right rear caliper froze. Front the rods as well. And of course right when I was done with all that my right rear window decided to die in the down position.... Just tried a new window motor and nope I need the entire regulator so I'll be ordering a new one of those.
Does anyone have recommendations for driver seat replacement leather seat bottom that won't break the bank. As well as replacement side mirrors that have the puddle lights
Thanks in advance
That looks awesome. Was it pretty straight forward to replace? Someone who is mechanically incline could do it in an afternoon? Any special tools needed?View attachment 183153
Nope, replacement shocks are MonoMAX for a 2-5" lift. Mine isn't leveled, I have Z71 springs and 2" spacers, rear fender heights are 40 1/4", while the fronts are at 39 1/2" (have 285/75/16's for tires). I don't know how some guys are getting 41" or more on the fronts, my UCA's would almost be riding on the limit steps, if I still had them - mine would bang when when going into full droop (or lack thereof) when I would go off-road. Conceivably, I could crank my keys more, max out the passenger side and get another inch plus, and match the passenger side..... but my wallet would be empty all the time, I'd be going through front end parts at least every six months.
I used Richmond Auto Upholstery https://leather-auto-seats.com/ and have just received the best customer service from any company I've ever dealt with. I bought the front bottoms in January 2015 and recently the driver side developed a weird wear area and they sent me a replacement as well as some jute to help the worn padding, free of charge even though the warranty was up over 2 years ago. I've never had better service and their covers are top quality too.No pictures buy I ended up buying a magnaflow exhaust off eBay (one I posted a few weeks ago) and over all not bad the tail pipe was angled a little low so I ended up weldibg a factory hanger to the tailpipe to get it a little higher. Sounds good and fixes my problem. Ibalso changed rear brakes because right rear caliper froze. Front the rods as well. And of course right when I was done with all that my right rear window decided to die in the down position.... Just tried a new window motor and nope I need the entire regulator so I'll be ordering a new one of those.
Thanks in advance
There are write-up on the retrofit however alot of the NBS came with the filters. I'm not sure what year they quit putting them in but my 02 has them.
