Battery
malones99
Took my 15 Tahoe to get an oil change today. Dealer said the battery is failing. The battery is very expensive, around $350. Anyone else had to replace their battery?
chicagofan00
Arizona
Had mine replaced already but it was under warranty and didn't cost anything.
chicagofan00
Arizona
No but I just chalked it up to having at the time gone through 2 Arizona summers, which usually do a number on any car battery I've had.
malones99
malones99
Holy crap, $350? WTH? Is that normal these days?
I know! I even check AutoZone, and they were at $215. I'm not convinced, I hear a grinding noise in the morning when I turn it on (push button), and they said it was the battery. No check engine, no nothing. Hummmmmm
jeffbco
Blueinterceptor
There are only so many companies that manufacture batteries in the USA. Ac delco is one on them.
I usually replace my battery when I first get my Tahoe with an ac delco gold. More cca more reserve capacity. And a longer warranty.
I'd check what they are giving you vs what you have. It just might be a better battery.
jeffbco
You're right - very few manufacturers...but AC Delco is not one. Its batteries are most likely made by a Johnson Controls owned or controlled company.
PG01
Up here to the right
Die Hard from Sears. They will replaced for free.
This.....have dual die hard golds in my 13 hoe and not a problem after orig died within a year....
i read or watched something that most standard batteries are manufactured at the same plant and diff stickers or colored cases are slapped on
jeffbco
Thanks...but the question was for the poster (HiHoSilver in post #13) who installed the Interstate battery.
JeffK
