Front AC not blowing cold rear AC blows cold wtf
ivin74
05 NBS Nali
Htown, Texas
So its been about two months since I drove my 05 YD and yesterday when I went to drive it the front ac was blowing but not cold so i turn the rear ac on and it was blowing cold as hell. Has anyone gone thru this issue before, what could have broken?
Prince13
same, my 2001 tahoe does the same. im gonna do electric fans soon to see if it helps
M1Gunner
Gainesville, Fl
Electric fans will not resolve your issue. If the rear is cold then the fan and clutch are working properly because there is only one condenser for the dual system.
Since the rear is working properly that means there is sufficient refrigerant in the system. Your condenser is getting proper flow and air. Your rear evaporator is the same.
So either it is a refrigerant flow issue in the front, an air flow issue in the front (for example your Cabin air filter is clogged) a mechanical failure such as a blend door failure.
I would start by checking the cabin air filter just because it's the easiest. Then report back.
M1Gunner
Gainesville, Fl
@ivin74 just realized you have an 05 and I do believe cabin air filters were not an option after 03/04? But I may be wrong? If that's obviously the case then that's ruled out.
Prince13
mines blows cold at high rpms, gonna check that cabin filter.
M1Gunner
Gainesville, Fl
Now you're throwin in more details that are important. So high rpm it blows cold. As in high rpm at idle or higher rpm while driving down the road? Anything else that you have notice?
ivin74
ivin74
05 NBS Nali
Htown, Texas
M1Gunner, you are correct I don't have a cabin filter, I'm going to take it to the shop to get the AC checked as soon as i get it back on the road, Right now i'm installing a drop kit and is out of comission
Prince13
thank you for replying, greatly appreciate the help. by high rpms i do mean when im driving, when its at idle it wont blow as cold.
D-YukonXL
Hello I understand this is an old post.
2004 Yukon XL 1500, auto climate control.
But I am fighting similar issues. Rear ac blows very cold. Front, more so drivers side, vents blow just air it seems while in ideal. Once I begin to drive, they blow "cooler" air, you can tell the ac is trying.. but the passenger side seems to be just a bit cooler. It seems I can only get the front to blow cooler air when the rear is on. I've turned it off just to see what the front does, seems to stay decently cool. Slowing down it gets warmer again.
Driver side use to be screaming hot! So I replaced the temperature mode actuator, the one closest to the floor towards middle. Once that was replaced, no more super hot air. I've also removed it and open and closed it manually and it still seems hot air is mixing with the cold.
Haven't done anything with the condenser or the evaporator.
Both hard to get to. Haven't replaced the other 2 actuators.
And the accumulator is obviously working properly.
I've replaced the climate control module, unfortunately it's not an OEM.. apparently those are hard to come by. But it seems to work. The factory one was glitching bad! I've done the pull fuse, let sit, let recalibrate/relearn several times. It honestly seemed to work a little. I've checked the freon levels, doesn't need anymore.
Helps is much appreciated.
ivin74
ivin74
05 NBS Nali
Htown, Texas
How old is the compressor? Have you tested the system for leaks? If the compressor is new or in good shape, the next item I would replace would be the accumulator.
Alot of times the accumulator gets overlooked and that's the culprit .
ivin74
ivin74
05 NBS Nali
Htown, Texas
I forgot to follow up on this issue back in 2017, I ended up replacing the actuator on top of the dash and the one by the passenger side floor board behind the center console. That fix the issue and the suv has been good so far.
vsaravia
