My gfx got this for me today. I need to make the hole above the glove box for the light still.
I also put the Falkens on the rear of the Hoe.
YukonXL04
The Riverboat
Arlington, TX
Changed the oil, and my water pump was leaking coolant. I changed the pump, hoses, belts and all that about 15k miles ago. But when I changed it, the pump wasn't bad, just the gaskets. So I assumed same thing this time.
Pulled the pump, cleaned it all, new gaskets and tried rtv on the gaskets this time. Still freaking leaking! And it's not the pump.... not sure but coming from the passenger side Where the pump bolts up
Thermostat housing maybe?
S33k3r
Dallas, Texas
I replaced the incandescent reverse bulbs with LEDs on my Suburban. Somehow it's still not bright enough to backup without rolling the windows down, after dark... (Did the same to my wife's Tahoe a week or so ago).
Cattivo
The Concrete Jungle
Installed two 52mm gauges in the clock bezel after cutting out some 1/4'' ABS plastic. I used Q-bond to glue it all together... I'm probably going to redo it since I rushed it and the gauges aren't at the same height
Also need to find my 4 gang clip panel to mount all the rocker switches below the 52mm gauges
Escalade2007
