Changed the oil myself for once. Didn't realize how easy it was on these trucks. My dad got in the habit of having our mechanic do it when he had a Ford because they were a PITA. I ended up having to drive a screwdriver though the old filter because none of my tools fit it :confused: but the new one went on no problem.
A cheapo strap wrench works great.
I think I have the perfect frame for your rear plate, I'll check when I get home. It's black carbon fiber just barely wider than that white border. I have one on mine. If I have it still you can have it if you want it.
Let me know if you still have it or send me a link to it
The one I have left over is not the right one, it's too wide and covers too much. I remember now, I ended up with a powdercoated stainless steel one like this. http://www.ebay.com/itm/Slim-Black-...with-2-Hole-/382177619727?hash=item58fb8faf0f
PG01
Up here to the right
Auto Zine, im pretty sure, is where i gots mines... fits perfectly.... except the screw tabs on bottom and i know... i know i gotta cm my plate bolts....
Ps @yates ™ heres a close up of my plate# for ya.....dad.....
M1Gunner
Gainesville, Fl
Cattivo
The Concrete Jungle
350 ain't too bad. The fitment looks pretty spot on? Nice and tight, thick, no wrinkles. Are they neoprene material?
Those definitely look good brother @Cattivo
They fit and look perfect except for a small portion of the front seats where they didn't cover the seatbelt area...they were in the Hoe but I swapped them out for the Escalade leather seats
they're neoprene material
M3kanic
dantheman
Houston
texas heat problems. damn rear view fell off tuesday morning. went to put it back on last night and i didnt get enough adhesive on the button and it fell off again when i was adjusting the mirror. unplugged it all and will be reapplying it tonight.
same exact thing happened on my lexus 2 weeks ago.
M1Gunner
Gainesville, Fl
95escahoe
Here's mine installed. I used black snap covers from Ace Hardware to cover the screws. You could use these to cover your security screws @95escahoe.
Thanks that looks great, I think I can use the caps that come with that plate looks like the white base goes on then the screw goes in and you pop that cap on
brian.roberts.1293
Durham NC
Anybody good with hvac problems?
Tried Pulling some fuses didnt fix it.
1 HVAC Trouble Codes:
• B0229: CURRENT/HISTORY - Check report for description.
2 Rear Climate Control Panel Trouble Codes:
• B3531: CURRENT/HISTORY - Air flow control #10 (rear) circuit malfunction
• B0429: CURRENT/HISTORY - Check report for description.
Did you have a check engine light on for these codes?
Escalade2007
