Front End Noise
I also vote Timken. I went with them myself after hearing they're indestructible.
lkrasner
Another +1 on the timkens. Watch out though, there were knock off ones that weren't actually made in the US floating around on amazon/ ebay for a while. I forget exactly what it was, but there was an easy way to tell.
Also not always an easy job. The hubs tend to fuse themselves to the vehicle over time, especially if you live somewhere with lot's of road salt (thanks Michigan). Mine took a LOT of work to get off. I ended up using a grade 8 Bolt stuck through one of the wheel lug holes, with a nut on the back driving into the knuckle. Still stripped out even a grade 8 before it came loose with some air chiseling as well.
David Smith
David Smith
Savannah, GA
Wow. Fortunately, these are not bad to come off. I have already replaced both of them once. No salt down in GA!
David Smith
David Smith
Savannah, GA
Awesome, RH wheel bearing is the culprit! And Timken is hands down first choice for bearings.
Keep us updated man!
So when you make a left turn and it goes away, it is the right bearing? I have seen other people say the opposite on line. I have no idea really. I intend on changing them both, just curious for future reference.
M1Gunner
Gainesville, Fl
No no no crap Im messing you all up. When you swerve left it loads the vehicle weight onto the right. So if The noise goes away swerving left then it's the LH bearing. If it gets doesn't go away or gets louder then it's the RH bearing.
HiHoeSilver
Away!
Chicago
Almost replied to this earlier, wanted to see what you said. Lol. This is correct now. Turn left, weight goes right, noise stops, left bearing. And vice versa.
David Smith
David Smith
Savannah, GA
The bearing(s) have really started talking to me over to weekend. Can't wait for the new ones to get here tomorrow! Ready for a quiet ride again.
HiHoeSilver
Away!
Chicago
All I have to do is drive home from work today, then drive back to work tomorrow. I am having the new bearings delivered to my work and installing them 1 mile away from my work.
I got scared when mine got so loud that I got a ride to /from work for two days while I waited for the new ones. When I took them off it was pretty clear that they would not have come apart. You should be okay.
David Smith
David Smith
Savannah, GA
I will hold you accountable! lol
The spindle nut is never to be reused. The wheel hub and bearing bolts can be reused. These torque to 133 ft lbs and the spindle nut to 177 ft lbs on my 4WD '09 Yukon anyway.
Think I'm going to change mine as the noise in the cab is getting louder and louder unless I swerve or turn right too!
JasonW4141
