Low oil, excess carbon buildup
petergriffen
so I have a 2012 suburban that is still under the GM used certified warranty. Wife was driving the other day and a message came up Low oil pressure turn off engine. Got it towed in and it was four low on oil. They said they think it is because of excess carbon buildup so they're gonna put some cleaner in the engine let it sit for a few hours and see if that stops the oil consumption. Last oil change was done by chevy about 2500 miles ago
I called them and said I was worried about engine damage and wanted them to check into that and they said they have to do this first step and they will see what happens is there anything else I should know about this?? I just want all that can be done under warranty before it is out of warranty
Thanks!!
smccollamjr
4 qts in 2500 miles is a lot. I would think you'd easily see that on the ground or coming out of the exhaust.
Well, will they delete the AFM instead if they have to replace any AFM lifters or other components?
Mine works perfect but since it is not necessary, it's coming off soon.
Plimbob
Des Moines Iowa
I have an 07 Tahoe with 234,000 and it has used a quart every 1200-1500 miles for the last 150,000. About 6 months ago I went out and got a plug-in Range unit that turns off the AFM. Little or no oil consumption between changes (every 3,500) since. The unit plugs into the scan port and because you are still under the certified warranty you can remove it prior to taking it in for service and the engine will go back to its normal operating process.
I assume the 2011 use the same AFM process that the 07 does. There are a bunch of threads on the site regarding AFM and it effect on oil consumption.
You may want to do some research into it.
08grey
Was there ever a year where they got the arm right on the nnbs? Without having to change valve covers ect?
Sent from my SM-G950U using Tapatalk
P
petergriffen
Thanks for all of this. Is there anything I should try to get then do in addition as I am still under warranty? I'm going to keep pushing it to get all I can put of it.
Currently they want me to come back after 1000 miles and check the oil level. They also said it may be from bad gas not having cleaning agents and I should use come cleaner at every fill up. They replaced a few plugs as they were very dirty.
Kenny D
Crosby, Tx
I think the AFM is the main culprit of oil consumption. Mine is turned off via tuner and I haven't lost any since my last change about 5000 miles ago.
Plimbob
Des Moines Iowa
Chris,
I would suspect they are going to continue to blow smoke at you on this about being bad gas, bad plugs, blah, blah, blah, etc. The dealer has to be aware of the AFM effect on oil consumption. The reason there are dirty plugs is more than likely the AFM. I had issues with #1 and #7 fouling until I turned of the AFM.
I would suspect the dealer can't/won't tune it to shut off the AFM so they are going to continue to band-aid the wound until they aren't liable for warranty.
Like I said look in the previous post there are numerous threads about this topic and the positive effect of turning off the AFM whether by a tune or by the Range AFM unit. I think the range unit is approx. $299.00. I bought mine from one of the guys on the forum, he had is truck tuned so he didn't need it anymore. I wouldn't go back to running mine with the AFM, the truck runs better and stopped consuming oil.
harbison
1. Was carbon buildup on both banks? I had excess carbon buildup on the left bank (driver's side). This was caused by a bad PCV valve which GM redesigned. It is built into the valve cover. This would cause excessive oil consumption and carbon buildup.
2. I recently had mine tuned to remove AFM and have a Range AFM unit. PM me if you're interested.
P
petergriffen
Yeah thanks. I won't be doing anything until I'm off the warranty as in turning off the thing. I'll check to see if it was only on one side. So pretty much there is nothing gm will do for it?
Gas mileage go down a bit once off?
08grey
There is 13 I want to buy off a friend and I swore they would have gotten it right by then. Guess not.
Plimbob
Des Moines Iowa
Regarding gas mileage effect, I haven't noticed much difference in mileage with the AFM turned off and like I said previously the vehicle runs better and essentially no oil consumption between oil changes now.
P
petergriffen
So it used a qt in about 700 miles. They are going to replace the pistons and rings next week. Is there anything else I should push for while I am still under warranty? Will they extend the warranty because they had to do this work?
mizzouguy
Lake of the Ozarks, MO
Warranty won't be extended. Service dept may warrant the parts/labor they install for a set amount of time but it will not affect your vehicle or powertrain warranty.
If they are doing that much of a teardown be darn sure to get a reciept....thats a lot of parts.
Do they have an engine shop in house? May want to find out if they are going to send the block off to get machined/honed or the heads to get resurfaced.
Thats got to be so much more expensive for them compared to putting in a new longblock...thats basically a total rebuild. Pistons are last to come out of a bare block besides the crank.
Maximus1
Ok so my experience with the 5.3L and oil consumption ( around 1 qt between oil changes) is the PVC. The problem is that the aftermarket ones come with a tiny hole and no stopper inside. Do not buy this one because your engine will suck oil into the intake manifold and slowly you'll lose oil. If it's the factory PVC the stopper is worn out and allowing oil to pass by causing the oil lose. Replace it with a OEM one which means that more than likely you will have to replace the valve cover on the drivers side because the PVC is built into the cover and cannot be removed.
Bentley95
