How does your gmt800 truck look right now ?
04Huck
"I'd rather be lucky than good"
Buford, Ga
The other truck
Sent from my VS990 using Tapatalk
tahoe ed
ohio
What a headache i have been having with my truck wont start new fuel pump ignition switch ignition control module no security light any suggestions???
Jacoby
Lake Village, AR
Rub much? I'm adding 5100s to my TGC 2.5 soon. Goal was to get back some of the level I lost by putting a 1" in the back and make more room for 295/60s.
No rubbing at all, that's why I went with the 275's. They're almost a 34" tire but without the width. Doesn't stick very far outside the fenders - and sling mud, rocks, etc down the side of your vehicle. I don't know that I would go with longer shocks...the more you expand the coil springs the stiffer your ride will be. I did that with Toyota I had and it was the worst decision. My advise would be to add more lift on top or underneath the coil spring and add extended a-arms to allow more travel for everything. It took me several years of vehicles and lift kits to realize a-arms are the best thing for leveling kits. Also helps with alignment and ball joint wear. That's what I would do vs new shocks!
NGAneer
NWGA
It will be underneath, the adjustment is below the spring seat so the coil stays at the same height. I'm only going up 1 notch also, so not too much.
I'm not due for tires for a while but I'd like to get something 34x12-ish. I like my 305s but they're a little short for me and while I don't blame you for the 275s, I like the width.
Jacoby
Lake Village, AR
275/65/20 is definitely the way to go then
M1Gunner
Gainesville, Fl
You need three things sooo do us a favor... Check fuel pressure. Check for spark. Check for injector pulse and report back...
bottomline2000
Dallas, TX
Check your crank sensor. It's behind the starter.
MadDogDelpho
Texcellent
Yep. Out of a little town near Dallas. Used by some of the higher-ups so it's in real good shape.
dizhai
