Intake
Saul perez
What intakes y'all got and how much of a difference did it make
Sasquatch
Orange County N.Y.
I have a spectre with an AEM dry filter, And even though they`ve been dyno tested and do make extra horsepower you will never feel a difference.
Chubbs
"Intake" meaning some expensive plastic tube & open air filter? isn't going to do anything until you increase the throttle body bore. But there's no point unless you are upgrading the top end and trying to cram every lb/ft of air possible. Save your money for a full blown mod or maintenance items like brake pads & oil changes.
5dollar
Chubbs, so what about wrapping the air box and intake tube with heat reflecting material to help cool air coming in?
In theory this should improve performance but not likely enough to make a difference you would notice.
Actually our TB's are plenty big enough all the way to 500 hp or better. A bigger one is a waste of money unless you manage 550 hp or more. I'm running a stock one with a Whipple, headers and next week a cam. And I'm still pulling plenty of air through the stock TB.
Chubbs
I believe you. What is stock mm anyway? I saw 90mm TB bore (aftermarket) & like WTF....
Chubbs
Right. The whole theory behind air intake is colder, faster, and largest quantity possible. Until you have a charger hooked up to an intercooler you aren't doing much of anything. The free-flow or open cone underneath the hood is actually drawing less, & much warmer air than the factory intake having outside air from the fenderwell rammed in.
Wrisktaker1
Waldorf, MD
I have an Airaid system with the cone filter and intake tube still sucking air from the factory location but when using my predator scanner the intake air temps seems to climb rapidly at a stop light or stop and go traffic usually 20-30° higher at times...what could that be?
95escahoe
Airaid intake tube on my 04 6.0 Escalade, slightly better mpg and sounds great at WOT, still uses the factory air box just replaces the restrictive intake tube so it's not a hot air intake like all the other options
HiHoeSilver
Away!
Chicago
You say "factory location" is the cone IN the box?
Chubbs
It could be lack of airflow around the vehicle itself, plus the surrounding heat from engine output adds to that factor. I think that sounds pretty normal especially when ambient temps are high like summer season. Am I wrong?
Wrisktaker1
Waldorf, MD
I have the afraid open box with heat reflective media and filter but the upper radiator hose runs directly under the intake tube which effectively then heat the intake tube a bit, but why at times does the intake air temps rise so much, anybody?
Sasquatch
Orange County N.Y.
When you`re stopped or in stop and go traffic the engine isn`t sucking much air in and also there is no airflow through the grille so under hood temps rise and heat soaks into the intake tube raising the temp. And as you know once you get up to speed the temp drops back down.
SuburbanLife
Running a Volant Air intake. Closed box. Sounds better underload, doubt any HP or MPG improvement but maybe slightly. Definitely less restrictive.
W8TVI
Traverse City, MI
I'm just using a K&N oiled filter in the stock box.
I think it helped MPG slightly (something like 1-2MPG, but it is probably just noise. I can save that much just by changing the way I drive), and it feels peppier.
I can also hear the intake noise better, so that is a plus in my book. :D
yukonoffroad27
Kentucky
So if someone got one of these cheap (40$-60$) intake kits on eBay, what kind of air filter would you need and where could you get one for it?
Sasquatch
Orange County N.Y.
I have a spectre cai, They come with an oiled filter but i swapped an AEM dry cone filter. They`re washable and i bought two so i always have a clean one waiting in the garage when it`s time to change it.
I`m pretty sure i got them on ebay.
vsaravia
