DarkTahoe00
IN
Well not sure why the link didn't work but go to the forum's FB page I was able to upload it there and is working!
95escahoe
I just kind of lucked out. Does GM still sell them new?
Nope no longer made or sold by them might get lucky and find a dealer that has one laying on the shelf (if you go to the dealer they can search it across the US and get it sent over if they find it) or a pick and pull from what I gather they are pretty rare
Danny3737
Try Trunk Monkey, if they don't have it they might direct you where to find one. I've used them a few times and they have always been helpful
Wow, makes that second one I have worth something!! :happy107:
Chubbs
Shaggy pulled our boat for the first time. This usually is my Dodge Ram's job, but we had three of our kids with us.
Those wheels look good on your truck! Does it have the zW7 premium ride suspension with self-leveling shocks?
Chubbs
did the evap solenoid, charcoal canister and ended up having to lower the tank and blow out the vent lines. but after doing that it seems to be working properly again.
What kind of problems were you having to warrant this labor?
jaywoo65
Cabot, AR
Thanks! Nope, it's not a self leveling suspension. Tongue weight on that trailer isn't too bad though.
Chubbs
I got the oil pressure switch replaced @ a cool $60.
$50 for the BW switch w lifetime warranty @ Oreillys.
$10 for the low-profile 1-1/8 socket that is required to get to it @ back of the motor.
That o/p switch looks like it should be worth no more than $12; it's a rip off.
Look at this racket!! $60 for what? $15-$20 worth of stuff?? Man you bi*** a lot.
:p
Chubbs
No, it's not too bad. Boats are super heavy. For something that is bouyant, at that.
dantheman
Houston
Tighten gas cap messages and issues filling it up. Would click off the pump at like .8 gallon as if it was full. Tank vent line was clogged with charcoal pellets from the canister
Chubbs
what a PIA. have never heard of that, seems you and I are on the same wavelength with luck, haha
seven9st surfer
Milton, FL
I had pretty much the same thing happen to me about a year ago. Occasional CEL, but would stop filling at every gallon or so. Had to basically trickle-fill, super annoying. Luckily just replacing the evap solenoid did the trick, so I didn't have to drop the tank.
NjA4207
