Water in my doors
Theresa
there is an abundance of water filling up in my rear door panels of my 2014 Tahoe? Window seems super loose. Brody it to dealer and they told me they were meant to fill and drain through bottom of door panel. I feel like it's going to become a rust box really quick. I know this has been an issue in the past with other Tahoes and yukons .. Anyone have any ideas on how to rectify this situation ? TIA
about20ninj45
there was a post on here from a gm service rep that said it was completely normal for water to enter and drain inside the door. if you dont want the water in there, get some puddy to seal the weep holes, but, by doing that, the moisture may become trapped in there and pool with no way to drain, causing even more rust and corrosion.
NathanJax
Vacation Nathan
Jax, Fl
Basically yup.
Water will ALWAYS get in to your door. there's no way to completely seal it off if you ever want to roll your windows down.
There are holes in the bottom of every door that should be allowing the water to drain out. If water is staying in them, the drains are plugged. Take a nail or screwdriver and try to unplug them
PG01
Up here to the right
There are plugs in the weep holes. I was told to take out some of the plugs.
At the very least clean them. Taking one or 2 out wont hurt but now leaves a larger hole in bottom of door, no big deal again but i guess rubber is there to keep large bugs out....;)... kidding...? Aesthetics
Kenny D
Crosby, Tx
I actually have to reach down and pull the seal away from the bottom of the door with my finger to get mine to start draining. Doesn't seem that mine are clogged but the rubber weatherstrip at the bottom seals them up when the door is closed. The plugs you guys are talking about are the plugs that hold this rubber strip on? That is the only plugs I see.
PG01
Iirc there are 2-3 oval plugs with a rubber flap in them at underside of door .... def on hatch
Kenny D
Crosby, Tx
I've seen the ones on the hatch, I need to get a mirror and look closer to the doors I guess.
PG01
Im wrong kenny, you are absolutely right....the plastic clips/holes apparently double as the drains
Grabbed this off google...
However, for the newer Tahoes, the weatherstripping and the plastic screw/clips that hold it on place fasten into the drain holes (vs. separate / open drain holes like in the picture above).
The plastic fastener clips do have vertical channels cut into them to let the water drain out, but, not enough to prevent dirt/ debris from clogging them up. And, it doesn't take a whole lot to clog them.
Kenny D
Crosby, Tx
Yea, I can just lift the seal away from the door and it just flows out of the corners of the door but if the doors are closed, the seal keeps them shut and no water drains. So I got to make it a habit to open the rear doors after a rain.
KATfishing
I have some rust forming behind the rubber strips at the door seams. I removed the strips and liberally sprayed Fluid Film on the seams and also using the straw inside each of those holes. The holes were not clogged, but my goal was to help stop/dramatically slow down the rust. Guessing I'm doomed, but I figured, what can it hurt? Anyone else do this or something similar?
Mickey_561
Basically yup.
So I am New Here but Someone Please Help Me Out with my understanding of this situation/issues.
I have a 2013 Yukon and Never before Today has this happened. Now it Sounds Like 5 Gallons of Water in each back door Sloshing Around. I understand about the Drainage and Make Sure They Are Draining Good.
So Doors are Designed to Fill Up With Water?
Do these Vehicles come with Marine Speakers in them?
Why would GM Design to Allow Water inside of the Doors?
Please help me understand this Anyone…
PG01
They’re not designed to fill up of water but if you think about it there’s a piece of felt trim that goes on the outside so the window goes up and down and rides against FeLt even new but mostly older vehicles that felt gets damaged wears out from the sun weather whatever so Water gets in it’s not completely sealed unit otherwise like nathan said you wouldn’t be able to open the window as the felt breaks down water gets in there’s holes in the bottom of the door so that when water gets in it drains out I felt breaks down water gets in there’s holes in the bottom of the door so that when that water gets in it drains out
Bwaldron
